×Hey I use pipelines to build my application and it worked great. Today, however, this problem appeared:
[RuntimeException] /opt/atlassian/pipelines/agent/build/node_modules/debug/debug.js:126 debug.color = selectColor(namespae); ^ ReferenceError: namespae is not defined at createDebug (/opt/atlassian/pipelines/agent/build/node_modules/debug/debug.js:126:29) at Object.<anonymous> (/opt/atlassian/pipelines/agent/build/node_modules/eslint/lib/code-path-analysis/debug-helpers.js:12:29) at Module._compile (module.js:413:34) at Object.Module._extensions..js (module.js:422:10) at Module.load (module.js:357:32) at Function.Module._load (module.js:314:12) at Module.require (module.js:367:17) at require (internal/module.js:16:19) at Object.<anonymous> (/opt/atlassian/pipelines/agent/build/node_modules/eslint/lib/code-path-analysis/code-path-segment.js:12:13) at Module._compile (module.js:413:34)
Judging by the
This is not a problem with my application but error on the side of the pipelines.
Piotr, looks like one of your dependencies or transitive dependencies debug.js has a typo namespae.
I found the issue https://github.com/visionmedia/debug/issues/358 and it should have been fixed.
The reason why it suddenly stopped working is that this time, on npm install, it pulled a newer version of debug.js with the error. You could try using npm shrinkwrap or yarn to fix your dependency versions
Looks like you misspelled "namespace"
Me or service of Atlassian? I do not even use this package. Look at the path:
It is not related to my project. Unless I am doing something wrong. Yesterday, however, everything worked and did not make any changes that affect building my application.
