Pipelines is too slow
ZenobiusJ
Every step costs at minimum 55secs due to the git clone.
We need a way to declare when we want the clone and artifacts operations occur.
I recommended in a ticket that the following be converted to bash scripts which would be injected into the container:
- git_clone(depth)
- artifact_save([]globs)
- artifact_restore(step_name)
ZenobiusJ
Yeah being able to decide what impact the step execution time cost is going to be a huge positive.
We've been able to mitigate the huge risk of npm installing assets to use gulp, browserify and sass by baking all those npm modules into a docker image we use, but when the team saw the unavoidable 55sec cost of each step, there was dismay.
I know there'll be an avoidable delay of container warmup for each step. but having these bitbucket* commands mounted at a configurable path would help speed everyone's build times up.
mwatson
July 5, 2018
So as I understand it - you have subsequent steps of a multiple step pipeline that only need the artifacts from the previous step, not the checkout, or sometimes don't even need the artifacts, they just execute commands?
Thus the close and artefact retrieval is time wasted for you?
ZenobiusJ
Really though, I invite you to see how circleci does this: https://circleci.com/docs/2.0/configuration-reference/#checkout
ZenobiusJ
As to your comment about needing to perform a git clone in order to know what to do:
I'd imagine that the whole pipeline yaml file is provided out of band separate from the git clone.
ZenobiusJ
July 4, 2018 edited
if you wanted to be even more cautious about what you're putting into peoples containers you could provide optional key like so:
bitbucket_api_location: /opt/bitbucket
Then we'd change the above calls to bitbucket_checkout, bitbucket_artifact_save bitbucket_artifact_restore would change to: /opt/bitbucket/bitbucket_checkout /opt/bitbucket/bitbucket_artifact_save /opt/bitbucket/bitbucket_artifact_restore
ZenobiusJ
@mwatson
How would I use it?
Like this:
with opt-in yaml key:
`git: [manual|auto (default)]`
using proposed bash scripts:
- `bitbucket_checkout depth`
  - `git checkout at commit with depth configured`
- `bitbucket_artifact_save glob glob glob`
  - saves all files found matching glob(s)
- `bitbucket_artifact_restore step_name`
  - restores all globbed files from step_name
pipelines:
  default:
    - step:
        image: our-image-based-on-node:8-alpine
git: manual script: - | bitbucket_checkout full npm run prod bitbucket_artifact_save ./client/build/**/* ./cilent/build/docs/**/* - step: image: atlassians-awscli-image name: publish
git: manual script: - | ls -al ./ bitbucket_artifact_restore setup aws s3 sync --delete ./client/build/ s3://our-bucket/releases/$BITBUCKET_BUILD_NO/ - step: image: cloudfoundries-concourse-ci-slack-resource-image name: notify
git: manual script: - | echo "complex json object" | envsubst | /opt/resource/out
If a step required files from the commit, my options here are :
- use artifacts to persist it through the pipeline
- run a git checkout
I estimate this would save roughly 40-50 secs for each step.
mwatson
July 4, 2018
Hi ZenobiusJ,
It'd be useful to better understand your use case.
If we made these operations able to be manually applied by the user, how would you use them to speed things up? What would you do differently to the current order of doing things? Would you not always need the git clone to determine what to do?
Matt Watson (Bitbucket Pipelines Development Manager)
