Pipelines xUnit compatible test results
Paul Stegler
March 2, 2018
What format(s) does bitbucket pipelines support for test results? I am using:
dotnet xunit -xml ./test-results/results.xml
and pipelines picks up the results.xml file but then when it parses it it detects 0 tests run even though the console output shows there were many tests run along with the results.
The documentation is very vague as to what they mean by xUnit compatible test results. Are they talking about the test results generated by xUnit.net? JUnit? Microsoft TRX?
The xml I'm getting back is
<?xml version="1.0" encoding="utf-8"?><assemblies timestamp="03/02/2018 12:02:08"> <assembly name="MyDomain.Tests.dll" environment="64-bit .NET Standard [collection-per-class, parallel (8 threads)]" test-framework="xUnit.net 2.3.1.3858" run-date="2018-03-02" run-time="12:02:08" total="17" passed="16" failed="1" skipped="0" time="0.193" errors="0"> <errors /> <collection total="1" passed="1" failed="0" skipped="0" name="Test collection for MyDomain.Tests.AssemblyExtentionsTests+Classes" time="0.029"> <test name="MyDomain.Tests.AssemblyExtentionsTests+Classes.Are_found" type="MyDomain.Tests.AssemblyExtentionsTests+Classes" method="Are_found" time="0.0290398" result="Pass" /> </collection> <collection total="5" passed="5" failed="0" skipped="0" name="Test collection for MyDomain.Tests.Validation.ValidationFunctionTests+WithinRange" time="0.029"> <test name="MyDomain.Tests.Validation.ValidationFunctionTests+WithinRange.Works_as_expected(value: -1, expectedResult: False)" type="MyDomain.Tests.Validation.ValidationFunctionTests+WithinRange" method="Works_as_expected" time="0.0288192" result="Pass" /> <test name="MyDomain.Tests.Validation.ValidationFunctionTests+WithinRange.Works_as_expected(value: 6, expectedResult: False)" type="MyDomain.Tests.Validation.ValidationFunctionTests+WithinRange" method="Works_as_expected" time="0.0000509" result="Pass" /> <test name="MyDomain.Tests.Validation.ValidationFunctionTests+WithinRange.Works_as_expected(value: 0, expectedResult: True)" type="MyDomain.Tests.Validation.ValidationFunctionTests+WithinRange" method="Works_as_expected" time="0.000017" result="Pass" /> <test name="MyDomain.Tests.Validation.ValidationFunctionTests+WithinRange.Works_as_expected(value: 3, expectedResult: True)" type="MyDomain.Tests.Validation.ValidationFunctionTests+WithinRange" method="Works_as_expected" time="0.0000072" result="Pass" /> <test name="MyDomain.Tests.Validation.ValidationFunctionTests+WithinRange.Works_as_expected(value: 5, expectedResult: True)" type="MyDomain.Tests.Validation.ValidationFunctionTests+WithinRange" method="Works_as_expected" time="0.0000054" result="Pass" /> </collection> <collection total="1" passed="1" failed="0" skipped="0" name="Test collection for MyDomain.Tests.AssemblyExtentionsTests+OpenGenericClasses" time="0.029"> <test name="MyDomain.Tests.AssemblyExtentionsTests+OpenGenericClasses.Are_found" type="MyDomain.Tests.AssemblyExtentionsTests+OpenGenericClasses" method="Are_found" time="0.0288412" result="Pass" /> </collection> <collection total="7" passed="7" failed="0" skipped="0" name="Test collection for MyDomain.Tests.Validation.ValidatorTests" time="0.039"> <test name="MyDomain.Tests.Validation.ValidatorTests.Validation_succeeds_as_expected(property: 0)" type="MyDomain.Tests.Validation.ValidatorTests" method="Validation_succeeds_as_expected" time="0.030325" result="Pass" /> <test name="MyDomain.Tests.Validation.ValidatorTests.Validation_succeeds_as_expected(property: 1)" type="MyDomain.Tests.Validation.ValidatorTests" method="Validation_succeeds_as_expected" time="0.0000988" result="Pass" /> <test name="MyDomain.Tests.Validation.ValidatorTests.Validation_succeeds_as_expected(property: 3)" type="MyDomain.Tests.Validation.ValidatorTests" method="Validation_succeeds_as_expected" time="0.0000316" result="Pass" /> <test name="MyDomain.Tests.Validation.ValidatorTests.Validation_succeeds_as_expected(property: 5)" type="MyDomain.Tests.Validation.ValidatorTests" method="Validation_succeeds_as_expected" time="0.000021" result="Pass" /> <test name="MyDomain.Tests.Validation.ValidatorTests.Validation_throws_as_expected(value: \&quot; \&quot;)" type="MyDomain.Tests.Validation.ValidatorTests" method="Validation_throws_as_expected" time="0.0081974" result="Pass" /> <test name="MyDomain.Tests.Validation.ValidatorTests.Validation_throws_as_expected(value: \&quot;\&quot;)" type="MyDomain.Tests.Validation.ValidatorTests" method="Validation_throws_as_expected" time="0.000223" result="Pass" /> <test name="MyDomain.Tests.Validation.ValidatorTests.Validation_throws_as_expected(value: null)" type="MyDomain.Tests.Validation.ValidatorTests" method="Validation_throws_as_expected" time="0.0001669" result="Pass" /> </collection> <collection total="1" passed="1" failed="0" skipped="0" name="Test collection for MyDomain.Tests.AssemblyExtentionsTests+ValueTypes" time="0.035"> <test name="MyDomain.Tests.AssemblyExtentionsTests+ValueTypes.Are_found" type="MyDomain.Tests.AssemblyExtentionsTests+ValueTypes" method="Are_found" time="0.0353826" result="Pass" /> </collection> <collection total="1" passed="1" failed="0" skipped="0" name="Test collection for MyDomain.Tests.AssemblyExtentionsTests+ReferenceTypes" time="0.035"> <test name="MyDomain.Tests.AssemblyExtentionsTests+ReferenceTypes.ReferencTypes_are_found" type="MyDomain.Tests.AssemblyExtentionsTests+ReferenceTypes" method="ReferencTypes_are_found" time="0.0352717" result="Pass" /> </collection> <collection total="1" passed="0" failed="1" skipped="0" name="Test collection for MyDomain.Tests.Validation.FailMe" time="0.007"> <test name="MyDomain.Tests.Validation.FailMe.WillFail" type="MyDomain.Tests.Validation.FailMe" method="WillFail" time="0.0066377" result="Fail"> <failure exception-type="System.Exception"> <message><![CDATA[System.Exception : durp]]></message> <stack-trace><![CDATA[ at MyDomain.Tests.Validation.FailMe.WillFail() in C:\code\MyDomain\common\MyDomain.Tests\FailingTest.cs:line 15]]></stack-trace> </failure> </test> </collection> </assembly></assemblies>
Andrew Bowen December 16, 2018
JUnit format is supported.
I found this post, where they state xUnit format is not supported.
https://bitbucket.org/site/master/issues/15836/pipeline-xunitnet-test-results#comment-43922683
prashant mvr
March 27, 2018 edited
when you say pipeline i assume that you are talking about bamboo build.
Bamboo does not recognize xunit result output format thats why you see 0 results.
One workaround is to convert the xunit results file output format to nUnit format which bamboo recognize's, so instead of xml in your command replace it with nunit and then give it a try.
dotnet xunit -nunit ./test-results/results.xml
The documentation states xUnit.
https://confluence.atlassian.com/bitbucket/test-reporting-in-pipelines-939708543.html
But it doesn't? Excellent.
Like makaron likes this
atlassian, bitbucket, ci/cd workflows, scale ci cd, bitbucket webinar, devops pipeline, continuous integration, continuous delivery, atlassian learning, software automation, developer tools, build and deploy, pipeline optimization, atlassian community
Scale CI/CD workflows faster with Bitbucket Pipelines 🪣
Join this webinar on June 25/26th to learn how to build secure CI/CD workflows using Bitbucket Pipelines and get tips from our own engineers on how to speed up builds and operate at scale.
Register today
