Pre-hook Scriptrunner script failing when upgrading to lastest Bitbucket and Scriptrunner
Paul Davis October 18, 2020
Pulling to the master branch requires a completed Change Request Script Merge Checks – Require commits to be associated with a Jira issue Bitbucket Settings
The master branch is always working toward the next release and is the basis for that release’s branch
Therefore, changes to the master branch are strictly controlled
Proper authorization, via a completed change request, is required
Hook Type          Require commits to be associated with a Jira issue
Note      Require a valid completed change request when merging to the master branch.
Condition            mergeRequest.pullRequest.toRef.id.matches("refs/heads/master")
JQL clause template        (issueType in ("Change Request", "CR Sub-task"))
  AND (status = "Completed")
Thanks for any help
Kyle Moseley
October 21, 2020
Hey I know we talked outside of this channel, but for posterity:
The solution here was this wasn't actually intended to be a pre-receive hook, but a merge check.
"mergeRequest" was undeclared because a pre-receive hook could be any type of push, not just a merge. So the merge check is where you would be able to use the "mergeRequest".
