Hi
I've setup mirrors of some external repositories on stash. As this feature is currently not available on stash directly, this is working the following way:
This works with all configured external repositories with one exception, which is repo [1]. If pushing the changes to stash, I got the following error:
remote: Communication breakdown with Stash. To ssh://git@<removed-long-url>:7999/al/alpine-conf-mirror.git ! [remote rejected] alpine-conf-1.7.1 -> alpine-conf-1.7.1 (pre-receive hook declined) ! [remote rejected] alpine-conf-1.8.1 -> alpine-conf-1.8.1 (pre-receive hook declined) ! [remote rejected] v1.8 -> v1.8 (pre-receive hook declined) ! [remote rejected] v2.0 -> v2.0 (pre-receive hook declined) ! [remote rejected] v2.0_alpha1 -> v2.0_alpha1 (pre-receive hook declined) ! [remote rejected] v2.0_alpha2 -> v2.0_alpha2 (pre-receive hook declined) ! [remote rejected] v2.0_alpha3 -> v2.0_alpha3 (pre-receive hook declined) ! [remote rejected] v2.0_alpha4 -> v2.0_alpha4 (pre-receive hook declined) ! [remote rejected] v2.0_alpha6 -> v2.0_alpha6 (pre-receive hook declined) ! [remote rejected] v2.0_alpha7 -> v2.0_alpha7 (pre-receive hook declined) ! [remote rejected] v2.0_alpha8 -> v2.0_alpha8 (pre-receive hook declined) ! [remote rejected] v2.0_al?pha6 -> v2.0_al?pha6 (pre-receive hook declined) ! [remote rejected] v2.0_beta1 -> v2.0_beta1 (pre-receive hook declined) ! [remote rejected] v2.0_beta2 -> v2.0_beta2 (pre-receive hook declined) ! [remote rejected] v2.0_beta3 -> v2.0_beta3 (pre-receive hook declined) ! [remote rejected] v2.0_beta4 -> v2.0_beta4 (pre-receive hook declined) ! [remote rejected] v2.0_beta5 -> v2.0_beta5 (pre-receive hook declined) ! [remote rejected] v2.0_beta6 -> v2.0_beta6 (pre-receive hook declined) ! [remote rejected] v2.0_rc1 -> v2.0_rc1 (pre-receive hook declined) ! [remote rejected] v2.0_rc2 -> v2.0_rc2 (pre-receive hook declined) ! [remote rejected] v2.0_rc3 -> v2.0_rc3 (pre-receive hook declined) ! [remote rejected] v2.0_rc4 -> v2.0_rc4 (pre-receive hook declined) ! [remote rejected] v2.0_rc5 -> v2.0_rc5 (pre-receive hook declined) ! [remote rejected] v2.0_rc6 -> v2.0_rc6 (pre-receive hook declined) ! [remote rejected] v2.0_rc7 -> v2.0_rc7 (pre-receive hook declined) ! [remote rejected] v2.0_rc8 -> v2.0_rc8 (pre-receive hook declined) ! [remote rejected] v2.0_rc9 -> v2.0 error: failed to push some refs to 'ssh://git@<removed-long-url>:7999/al/alpine-conf-mirror.git'
I have no idea what's the problem here and it would be much appreciated to get this working! Thx a lot in advance.
Yves
Hi Yves,
Sorry for the delay. It looks like one of the tags in that repository is corrupted, or at least not stored in UTF-8. This is causing our backend hook implementation to fail and reject the entire push:
My suggestion for now would be to remove/rename* that tag (it looks wrong anyway), which will allow you to proceed. I'll talk to the team on Monday and let you know if it's actually a bug, or something we just don't support.
Charles
* I fixed the problem on my machine by editing the '.git/packed-refs' file manually. It's not something you should normally do, but it's easier than trying to pass that tag name into 'git tag -d'. These are the lines corresponding the broken tag. If you want to delete the tag you will need to remove both lines.
69333487c536a9399349ded67e52e9c7d6f6503d refs/tags/v2.0_alĂpha6
^93d5de03310c1a9aeaadc1d2e719055195d846a5
Hi Charles,
thx for the answer. We removed the two lines on packed-refs and now the sync works as expected. Thx a lot for your help!
Yves
HI Charles,
We are seeing the same issue and we tried to remove the corrupt tag and retried however we are still facing the same issue.Any other cause for this?
Regards
Vishnu
@Vishnu Reddy K Sorry, I haven't worked on Stash in a few years. Would suggest raising a support ticket.
