Problem with Bitbucket pipelines
Ingrid Hyltander
May 11, 2018
I'm having a a really silly and frustrating issue. I'm currently working at a start-up and I'm trying to get started with Bitbucket pipelines for the PHP-based web portal of the company.
However, I can't seem to commit a bitbucket-pipelines.yml file for this repo(I have admin access). No matter what language, image or script I try, I always get the same, non-informative, error message "Something went wrong". Since I'm new to this and just playing around, the files are very basic, e.g:
When I try to commit the same bitbucket-pipelines.yml files I have tried to other repos it works just fine, so I assume there is something with the repo that causing the problem. The size of the repo is 5.4 MB and Git Large File Storage: 0 bytes of space used. (1.0 GB remaining) so at least I know that's not an issue.
I'm having a hard time troubleshooting this. Does anyone know what might be the problem?
12 votes
tri.nm
@Ingrid Hyltander
I found a way to get through the problem.
In my case, I do not have the push permission to the master branch.
I guess the "Commit file" button of Bitbucket GUI will commit the file to the "master" branch by default.
So I manually commited the bitbucket-pipelines.yml file to the root of other branch where i have write permission --> it worked.
Hope it helps.
Ingrid Hyltander
May 16, 2018
Ah I see! It worked for me as well, thank you very much!
5 votes
Nathaniel Rink
September 5, 2018 edited
Oh yeah, that's annoying. Nobody had the right to push changes directly to master without a PR and that simple issue with the non descriptive error could have taken forever to fix without this question
3 votes
Azzuwan
March 23, 2019
This problem is very "un-Atlassian". This sort of error handling is an outcast and doesn't belong in the high quality experience of BitBucket which I vouch for.  Fix it!
Sandesha J
August 19, 2018
But I have permission to the master branch, but still getting the same error
cakoster March 21, 2019
Come on, this error message is terrible.
Tiago Menegaz
October 18, 2018
Terrible work around but it works. I'd like to see a decent solution to this issue.
tri.nm
Me also. We do know that "Something went wrong", but what was that thing?
Really sill and frustrating !
