I have a problem with the subversion plus plugin. i use svn+ssh and when i try to connect to a repository i always get an error "ProtocolKeyFile It must be not empty string".
I don't understand why! Because when i use netbeans to connect to the same repository it works fine without an protocol key file.
It was a bug. It is fixed with version 3.1.6.
Hi Roland,
Subversion Plugin does require the id_rsa key when using svn+ssh. You can pick it on the home_dir/.ssh from the user which is running JIRA on your server.
Best regards,
Lucas Timm
Subversion Plus exists. It's not a typo! ;)
