Problema para migrar base de datos
Victor Rodriguez October 23, 2015
Tengo el siguiente problema al instalar y configurar la base de datos, alguien tiene la solución. Lo intenté con MySQL y con SQL.
image2015-10-23 16:13:5.png
gustavo_refosco
November 5, 2015
Hi Victor, I'll be answering in English, since this way more people will be able to look at this and try to provide some help. Can you please copy/past the entire text of the error, since the screenshot cuts it? Furthermore you may try to debug this, so you may get more info from the logs, as follows: 1. Go to "Bitbucket Administration > Support > Logging and Profiling", select "Enable debug logging" and click in "Save". 2. Try to perform the migration, reproducing the error. 3. Go to "Bitbucket Administration > Support > Logging and Profiling" and deselect "Enable debug logging" and click in "Save". 4. Check at the atlassian-bitbucket.log which is under BITBUCKET_HOME/log. If you prefer, you may also create a support ticket at https://support.atlassian.com Regards, Gustavo Refosco
