What will happen or the impact if I rename the project Name in Bitbucket server?
Hi @Yogesh Mude, the main thing that will change will be the URL of your repository, you will need to update the clients connected to it and the remote address.
David
Hi @david
Thanks for your answer .. If we rename the project then it won't affect on repository because project Key will contain in repository URL but not the Name.
