Quick reload for bitbucket.
Joel Suter August 22, 2017
How can i use the Quick reload feature. It says i need to use the "mvn package command". I cant run this command as it is, so i want to know what i need to run. I am running a localhost bitbucket server and when I change a Java class i dont want to do the atlas-run everytime. I linked the quickreload in the pom.xml. I just dont get what and where i need to run the command so that it works. Please can someone give a full explenation, the whole command, and where i need to run it(which directory and maybe in another cmd because of the localhost that is running in the other).
The Atlassian website gives no help with this problem, i dont have anyclue what to do. Is it a add on, does it work for bitbucket, how do I install it if i have to?
Ian Ragudo
July 19, 2018
Hi @Joel Suter,
This question is a bit dated, I do hope that you were able to figure it out already, but if you haven't, you need to run "atlas-package" on a separate terminal while your server app is still running (I assume you ran your app via "atlas-run"). Once the packaging is successful, go back to the 1st terminal where you ran "atlas-run" and see the logs as quick reload kicks in.
Ian
More info: I have no servlets just a rest module.
