Recommended workflow using the svn mirror plugin
Joseph Smith February 12, 2014
I now have the svn mirror plugin working for our organization. Now that the mechanics are working we are trying to determine the best workflow using feature branches and pull requests. Our basic workflow is:
1) Create a branch off of master for a given work item.
2) Once the work is completed, git push -u in order to create a remote branch on the Stash server so that we can issue a pull request.
3) Once the pull request is approved, merge that into master.
The one burdensome part of this workflow is that in order to merge back to master I need to git fetch --rebase the master branch and then merge that into the feature branch and then update the feature branch so that I am merging something that is consistent with the master branch (which is getting constant changes from svn).
This creates a sort of "rectangle" of branches, with my local master tracking stash's master and my local feature branch tracking stash's feature branch. Anytime a svn commit happens I need to rebase/merge that change from stash/master->local master->local feature->stash/feature.
I'm guessing there is a much better way of doing this. Any advice?
Joseph Smith February 13, 2014
That log file looks a bit odd to me - like the daemon is constantly restarting (is this expected)? In any case, most things work as expected, but we definitely cannot merge pull requests as you described. I've created this issue with the attached log: http://issues.tmatesoft.com/issue/SGT-833
Thanks for all of the help so far.
Semyon Vadishev
February 12, 2014
In this case the plugin may block pull request merge if someone has committed new revision into the same branch from Subversion side while the merge operation was in progress. Which presumably shouldn't happen too often. Can you please send us the log file <GIT_REPO>/subgit/logs/daemon.0.log to issue tracker or to support@subgit.com, so we can check whether it's a bug or not?
We are using 2.0.7
Semyon Vadishev
February 12, 2014
Older versions of the plugin blocked merging pull requests, but since version 2.0.6 we got rid of that limitation, so you can create and merge pull requests as if there'd be no mirror involved. What version do you use?
Yes, but the subgit plugin seems to be blocking the merge, even if the changes in master have nothing to do with the changes in the pull request, meaning that I need to update the feature branch much more frequently.
Semyon Vadishev
February 12, 2014
How that would differ from the workflow with no Git-SVN mirror involved? Changes may arive to Stash's master either from Subversion repository or from other Git users pushing to master, right?
atlassian, compass, developer experience, devex, platform engineering, internal developer platform, component catalog, atlassian learning, productivity tools, developer productivity, software architecture, compass webinar, engineering teams
Discover how Compass drives DevEx and productivity at Atlassian 🏃🏻‍♂️
Learn why Compass was built to tackle dev experience at scale. See how Atlassian uses it to boost visibility, reduce cognitive load, and drive consistency—plus tips to get started and customize your IDP for stronger team engagement.
Join the webinar ✨
