Can I get the report of bitbucket projects and repositories that are present in bitbucket?
Hello Ankita, you can achieve that by using the REST API. If you're on Bitbucket Server, you can find all the necessary information at Bitbucket Server REST API. If you're on Cloud, you can find it at Bitbucket Cloud REST API.
If you have any questions, let us know!
Ana
