Required plugin has failed to start
miguelramos
March 30, 2014
I've been fighting for some days to put this stash working but all i get is a bunch of errors. I realise that some plugins are failing installing and other things. Could soemeone show me the right way to resolve this.
Here are the logs:
2014-03-30 22:23:16,358 INFO  [localhost-startStop-1]  c.a.s.i.server.BuildInfoLogger Starting Stash 2.12.0 (c7cb5cd built on Tue Mar 25 06:42:52 UTC 2014)
2014-03-30 22:23:16,365 INFO  [localhost-startStop-1]  c.a.s.i.server.BuildInfoLogger JVM: Oracle Corporation Java HotSpot(TM) Client VM 1.8.0-b132
2014-03-30 22:23:18,140 INFO  [localhost-startStop-1]  c.a.s.internal.home.HomeLockAcquirer Successfully acquired lock on home directory /home/stash for 3363@bunkerbox
2014-03-30 22:23:20,404 WARN  [localhost-startStop-1]  com.jolbox.bonecp.BoneCPConfig JDBC password not set in driver properties, copying it from pool config
2014-03-30 22:23:41,189 WARN  [localhost-startStop-1]  c.a.s.i.license.LicenseServiceImpl No license has been configured.
2014-03-30 22:23:48,150 INFO  [localhost-startStop-1]  c.a.s.i.hook.DefaultHookService Hook callback socket listening on 127.0.0.1:57212
2014-03-30 22:23:51,148 ERROR [FelixDispatchQueue]  c.a.p.o.c.f.FelixOsgiContainerManager Framework error in bundle org.springframework.osgi.extender
org.osgi.framework.BundleException: Activator start error in bundle org.springframework.osgi.extender [2].
	at org.apache.felix.framework.Felix.activateBundle(Felix.java:1889) ~[org.apache.felix.framework-3.0.9.jar:na]
	at java.lang.Thread.run(Thread.java:744) [na:1.8.0]
	... 3 frames trimmed
Caused by: java.lang.IllegalStateException: Cannot create ConcurrentHashMap - neither JDK 1.5 nor backport-concurrent available on the classpath
	at org.springframework.core.CollectionFactory.createConcurrentMap(CollectionFactory.java:229) ~[spring-core-4.0.2.RELEASE.jar:4.0.2.RELEASE]
	at java.lang.Class.newInstance(Class.java:433) ~[na:1.8.0]
	... 2 common frames omitted
2014-03-30 22:23:57,820 WARN  [localhost-startStop-1]  c.a.p.o.f.t.s.ScanDescriptorForHostClassesStage The plugin 'atlassian-universal-plugin-manager-plugin-2.15.2.jar' uses a package 'org.apache.commons.fileupload.servlet' that is also exported by the application.  It is highly recommended that the plugin use its own packages.
2014-03-30 22:25:08,691 ERROR [localhost-startStop-1]  c.a.plugin.manager.PluginEnabler Unable to start the following plugins due to timeout while waiting for plugin to enable: com.atlassian.stash.stash-jira-integration,com.atlassian.plugins.atlassian-nav-links-plugin,com.atlassian.stash.stash-rest-common,com.atlassian.markup.atlassian-markup-plugin,com.atlassian.stash.stash-sal,com.atlassian.stash.stash-scm-request-checks,com.atlassian.plugins.rest.atlassian-rest-module,com.atlassian.stash.stash-rest,com.atlassian.templaterenderer.atlassian-template-renderer-velocity1.6-plugin,com.atlassian.webhooks.atlassian-webhooks-plugin,com.atlassian.scala.plugins.scala-2.9-provider-plugin,com.atlassian.stash.plugin.stash-scm-cache,com.atlassian.stash.stash-branch-utils,com.atlassian.stash.stash-scm-git,com.atlassian.stash.stash-branch-permissions,com.atlassian.stash.stash-hipchat-integration,com.atlassian.scala.plugins.scala-2.10-provider-plugin,com.atlassian.stash.stash-ao-common,com.atlassian.oauth.consumer,com.atlassian.stash.stash-notification,com.atlassian.stash.stash-pull-request-branch-deletion,com.atlassian.oauth.admin,com.atlassian.stash.plugin.stash-inbox-plugin,com.atlassian.activeobjects.activeobjects-plugin,com.atlassian.stash.stash-stp-integration,com.atlassian.crowd.embedded.admin,com.atlassian.stash.stash-embcwd-admin-spi-impl,com.atlassian.plugins.less-transformer-plugin,com.atlassian.auiplugin,com.atlassian.plugins.atlassian-dev-status-plugin,com.atlassian.httpclient.atlassian-httpclient-plugin,com.atlassian.oauth.serviceprovider,com.atlassian.plugins.issue-status-plugin,com.atlassian.healthcheck.atlassian-healthcheck,com.atlassian.upm.atlassian-universal-plugin-manager-plugin,com.atlassian.plugins.remote-link-aggregator-plugin,com.atlassian.plugins.shortcuts.atlassian-shortcuts-plugin,com.atlassian.integration.jira.jira-integration-plugin,com.atlassian.templaterenderer.api,com.atlassian.oauth.consumer.sal,com.atlassian.plugins.atlassian-chaperone,com.atlassian.applinks.applinks-plugin,com.atlassian.soy.soy-template-plugin,com.atlassian.stash.stash-bundled-hooks,com.atlassian.oauth.serviceprovider.sal,com.atlassian.stash.ssh-plugin,com.atlassian.plugins.atlassian-plugins-webresource-plugin,com.atlassian.stash.stash-build-integration,com.atlassian.stash.stash-auth-crowd-sso,com.atlassian.atlassian-failure-cache-plugin,com.atlassian.plugins.jquery,com.atlassian.prettyurls.atlassian-pretty-urls-plugin,com.atlassian.stash.stash-dev-summary-plugin,com.atlassian.support.stp,com.atlassian.stash.stash-sourcetree-plugin,com.atlassian.stash.stash-repository-ref-sync,com.atlassian.stash.stash-nav-links,com.atlassian.stash.stash-velocity-helper,com.atlassian.stash.stash-readme-plugin,com.atlassian.stash.stash-audit
2014-03-30 22:25:10,928 ERROR [localhost-startStop-1]  c.a.e.i.AsynchronousAbleEventDispatcher There was an exception thrown trying to dispatch event '[com.atlassian.plugin.event.events.PluginFrameworkStartedEvent@bd7441, SingleParameterMethodListenerInvoker{method=public void com.atlassian.stash.internal.scm.PluginScmService.onPluginFrameworkStarted(com.atlassian.plugin.event.events.PluginFrameworkStartedEvent), listener=com.atlassian.stash.internal.scm.PluginScmService@709d05}]' from the invoker 'java.lang.RuntimeException: No SCM has been registered with ID: git'
On browser at i received is this:
A fatal error has occurred
The following problems occurred which prevents Atlassian Stash from starting correctly:
Required plugin com.atlassian.templaterenderer.api has failed to start
Required plugin com.atlassian.stash.stash-jira-integration has failed to start
Required plugin com.atlassian.atlassian-failure-cache-plugin has failed to start
Required plugin com.atlassian.crowd.embedded.admin has failed to start
Required plugin com.atlassian.plugins.atlassian-nav-links-plugin has failed to start
Required plugin com.atlassian.templaterenderer.atlassian-template-renderer-velocity1.6-plugin has failed to start
Required plugin com.atlassian.oauth.consumer.sal has failed to start
Required plugin com.atlassian.stash.stash-rest-common has failed to start
Required plugin com.atlassian.stash.stash-rest has failed to start
Required plugin com.atlassian.applinks.applinks-plugin has failed to start
Required plugin com.atlassian.auiplugin has failed to start
Required plugin com.atlassian.oauth.consumer has failed to start
Required plugin com.atlassian.upm.atlassian-universal-plugin-manager-plugin has failed to start
Required plugin com.atlassian.soy.soy-template-plugin has failed to start
Required plugin com.atlassian.activeobjects.activeobjects-plugin has failed to start
Required plugin com.atlassian.stash.stash-sal has failed to start
Required plugin com.atlassian.stash.stash-embcwd-admin-spi-impl has failed to start
Required plugin com.atlassian.plugins.atlassian-plugins-webresource-plugin has failed to start
Required plugin com.atlassian.stash.stash-stp-integration has failed to start
Required plugin com.atlassian.oauth.serviceprovider.sal has failed to start
Required plugin com.atlassian.stash.stash-scm-request-checks has failed to start
Required plugin com.atlassian.scala.plugins.scala-2.9-provider-plugin has failed to start
Required plugin com.atlassian.plugins.jquery has failed to start
Required plugin com.atlassian.plugins.less-transformer-plugin has failed to start
Required plugin com.atlassian.oauth.serviceprovider has failed to start
Required plugin com.atlassian.stash.stash-scm-git has failed to start
Required plugin com.atlassian.stash.stash-nav-links has failed to start
Required plugin com.atlassian.stash.stash-velocity-helper has failed to start
Required plugin com.atlassian.oauth.admin has failed to start
Required plugin com.atlassian.plugins.rest.atlassian-rest-module has failed to start
Thanks for help me!
vladkras November 28, 2016
I'm not sure about your problem but google lead me here so I will post my solution.
I had to increase my RAM to solve all this "Required plugin has failed to start" problems. I have both Bitbucket and Confluence services on same server, so starting one after anoter caused too long waiting of this plugins to start. I assume defaut timeout is 300s which is not enough if you ran out of memory
While playing around with catalina opts like `Xmx` and `Xms` didn't help
ThiagoBomfim
March 30, 2014
Hi Miguel,
Could you please take a look at the Knowledge Base article below and give us a feedback
Stash failed to Start due to Required plugin failed to start
I am also interested to know about which values are printed below when you run Stash in the command line (mainly your JRE_HOME):
Using STASH_HOME:
Using CATALINA_BASE:
Using CATALINA_HOME:
Using CATALINA_TMPDIR:
Using JRE_HOME:
Using CLASSPATH:
Using CATALINA_PID:
Thank you!
Best regards,
Thiago Bomfim
Atlassian Support - DevTools
miguelramos
March 30, 2014
After digging a little bit more i founded that i was using JDK 8 and atlassian at the moment don't support this version. I've just downgraded to version 7 and now it is runnig without any issues.
Thanks for your help and sorry being dummy.
ThiagoBomfim
May 18, 2014
Hi Miguel,
Thanks for your feedback on this. I've updated the article I first linked you to.
Best regards,
Thiago Bomfim
Atlassian Support
