Rest API for Code Insight Code Coverage for BitBucket Server 7
bfierz
May 26, 2020
Is there an official Rest-API to add statement coverage information to an insight report? According to this overview, it should be possible: https://confluence.atlassian.com/bitbucketserver/code-insights-966660485.html
However, I cannot find anything in the official documentation: https://docs.atlassian.com/bitbucket-server/rest/7.2.3/bitbucket-code-insights-rest.html
The only way I can add statement coverage is by using the unsupported plugin: https://marketplace.atlassian.com/apps/1218271/code-coverage-for-bitbucket-server?hosting=server&tab=overview
Thank you
Kristy
May 26, 2020
Hi @bfierz
Code coverage has not been implemented as a core feature in Bitbucket Server yet. However, there is an API that can be consumed by plugins to provide this information.
The plugin you linked is one such plugin that consumes this API, and it was developed by Atlassian. However, as you mentioned it is not supported. You could also write your own plugin that uses the API, which can be found here.
Out of curiosity, what tool do you use for CI and code coverage? Its always useful to gather some customer feedback to help us prioritise features and develop the best solutions for you :)
Hope that helps.
Kristy
Engineer on Bitbucket Server
bfierz
May 26, 2020
we are using Jenkins for CI. As most of our work happens on windows we are using OpenCppCoverage for the job.
I was already successfully using the mentioned plugin on the 6.x series with a custom generator OpenCppCoverage, I will continue using this plugin in this case.
Thank you
atlassian, forge, forge learning path, atlassian learning, cloud app development, forge app development, build forge apps, atlassian certification, developer training, jira app development, confluence app development, automation, ui frameworks
Turn Ideas into Atlassian Apps 📱
From setup to deployment—this learning path shows you how to build your first app using Forge. Learn the essentials, streamline workflows, and bring custom solutions to life across Jira, Confluence, and more.
Start Learning
