We are using custom workflow types where we want to restrict the ability to create branches for connected Bitbucket instances. We have scriptrunner installed on both Jira and Bitbucket if that helps.
Hi Paul! You'll need to do that from the Bitbucket side. You can restrict the creation of branches by using branch permissions.
Regarding Scriptrunner, I personally don't know if it could help you achieve what you want, I'll leave that to someone from the Community :)
Best regards,
Ana
