×Hi Jason,
SubGit imports/synchronizes only those branches and tags specified on SVN settings page. So, in order to keep the history for all the previous locations of your trunk folder, please include all those locations into trunk & branches options just as follows:
Subversion URL = http://host/svn/repo
Trunk = dir3:refs/heads/master
Branches = dir2:refs/heads/old_master; dir1:refs/heads/even_older_master; branches/*:refs/heads/*
With these settings specified SubGit should be able to join the history for all three locations. Also, please consider reporting your issue to our issue tracker with more details (repository layout, how it was actually changing over time, `svn log` output for corresponding revisions). We'll try to provide you with all necessary instructions as soon as possible.
Semyon
Hi Semyon,
I attempted your suggestion, however it seems to result in an infinate loop during the initial translation of the import. The revision number count keeps starting over from the beginning after reaching the end.
These are my Stash Subversion Mirror settings:
URL : svn+ssh://svn.company.com/home/svn Branches Mapping: Trunk: dir3:refs/heads/master Branches: dir2:refs/heads/old_master; dir1:refs/heads/even_older_master; gitsvn/branches/*:refs/heads/* Tags: gitsvn/tags/* Shelves: gitsvn/shelves/*
Any other thoughts?
Regarding the issue tracker, I think my problem is the same (or very similar) to this issue: http://issues.tmatesoft.com/issue/SGT-721
Hi Jason,
This looks like a bug. Could you please send us debug log files located in <STASH_HOME>/data/repositories/<ID>/subgit/logs directory? You can find path to Git repository on Settings | Repository Details page.
You can report a new issue to our tracker with the logs attached or just send an email to support@subgit.com.
Thank you,
Semyon
Hi Jason,
Thank you,
Semyon
Of course. Sorry, that was a dumb thing to say. :(
My git-svn comment still stands, or otherwise or in any case I would recommend pinging the Subgit people on Twitter to get their attention.
Hi Charles, thanks for the reply. "git log -- dir2" does not work because the "dir2" is the root of the mirror. So "git log -- dir3" doesn't work either. However, I can see the oldest commit in the repo with "git log | tail -n 5", which is the commit creating "dir3"
Hi Jason,
If you run 'git log -- dir2' does it have any history? Or is Subgit not importing that at all?
Otherwise I know that git-svn can be better at importing weird SVN history, although be warned it's much slower than Subgit.
Charles
