Rsync deploy for multiple servers
Paweł Sobociński
October 12, 2021
is it possible to deploy via rsync (atlassian / rsync-deploy) and execute the ssh command (atlassian / ssh-run) to multiple servers simultaneously?
for example:
script:
- pipe: atlassian/rsync-deploy:0.6.0
variables:
USER: $USER_PRE_PROD
SERVER: ['IP_1', 'IP_2', 'IP_3']
REMOTE_PATH: $REMOTE_PATH
LOCAL_PATH: 'app'
when I run it like this I have such an error: /pipe.sh: line 27: SERVER: SSH_SERVER variable missing
env=BITBUCKET_PIPE_STORAGE_DIR="/opt/atlassian/pipelines/agent/build/.bitbucket/pipelines/generated/pipeline/pipes/atlassian/rsync-deploy" \
--env=REMOTE_PATH="$REMOTE_PATH" \
--env=SERVER_0="IP_1" \
--env=SERVER_1="IP_2" \
--env=SERVER_2="IP_3" \
--env=SERVER_COUNT="3" \
--env=USER="$USER_PRE_PROD" \
--add-host="host.docker.internal:$BITBUCKET_DOCKER_HOST_INTERNAL" \
Status: Downloaded newer image for bitbucketpipelines/rsync-deploy:0.6.0
/pipe.sh: line 27: SERVER: SSH_SERVER variable missing.
INFO: Executing the pipe...
Igor Stoyanov
October 15, 2021
Hi @PaweÅ‚ SobociÅ„ski . Thanks for your question. This feature is not supported, but you can use parallel steps where each script relates to each of your server. Example: Parallel steps
Regards, Igor
atlassian, bitbucket, ci/cd workflows, scale ci cd, bitbucket webinar, devops pipeline, continuous integration, continuous delivery, atlassian learning, software automation, developer tools, build and deploy, pipeline optimization, atlassian community
Scale CI/CD workflows faster with Bitbucket Pipelines 🪣
Join this webinar on June 25/26th to learn how to build secure CI/CD workflows using Bitbucket Pipelines and get tips from our own engineers on how to speed up builds and operate at scale.
Register today
