We have a site that uses Pipelines to deploy onto AWS Elastic Beanstalk, is there a way using either AWS and/or Pipelines to trigger automated tests (on Bitbucket) to run post deployment?
Hi @alexwhiteoval,
A workaround for this problem is to commit to the dependent repo after the deployment has completed to create a new pipeline there to begin the selenium tests. Another option is to manually post a pipeline creation request to the Bitbucket api for the dependent pipeline as detailed here https://developer.atlassian.com/bitbucket/api/2/reference/resource/repositories/%7Busername%7D/%7Brepo_slug%7D/pipelines/#post.
There's a feature request here https://bitbucket.org/site/master/issues/13661/trigger-build-of-dependent-repos-after and you can comment on it with the specifics of what you would want out of this feature.
Tom
That is correct.
To elaborate: once the first code deploy (web app) has completed, we need to then run the tests (selenium/saucelabs) in another repository in another pipleline.
Hey @alexwhiteoval,
I'm not sure I fully understand. It sounds like you're trying to deploy code from one repository using a pipeline and, when that pipeline has finished, to run tests stored in another repository in another pipeline. Is that correct?
From setup to deployment—this learning path shows you how to build your first app using Forge. Learn the essentials, streamline workflows, and bring custom solutions to life across Jira, Confluence, and more.
Start Learning
