×Dear All,
I'm new to bitbucket pipeline. Can we run svn checkout command in bitbucket pipeline step?
Regards
Sanju
Hi, @Sanju Ammu!
You can run svn checkout command in the Bitbucket pipeline step. You just need to make sure you have installed the SVN client before running this. You can run the following commands to install SVN:
apt-get update
apt-get install -y subversion
I hope this helps, but do let me know if you have any questions.
Caroline
