Script runner unable to resolve class for com.atlassian.bitbucket.scm
Pavan Kumar Nayakanti
March 16, 2023
Am trying to use below libraries to introduce a merge check
import com.atlassian.bitbucket.permission.Permission
import com.atlassian.bitbucket.permission.PermissionService
import com.atlassian.bitbucket.repository.RepositoryService
import com.atlassian.bitbucket.scm.pull.MergeRequest
import com.atlassian.bitbucket.scm.pull.MergeRequestCheck
import com.atlassian.bitbucket.scm.pull.MergeRequestCheckContext
import com.atlassian.bitbucket.scm.pull.MergeRequestCheckResult
import com.atlassian.bitbucket.user.SecurityService
But the script could not be compiled, due to inability of resolving below classes. What i might be missing here? Please advise.
org.codehaus.groovy.control.MultipleCompilationErrorsException: startup failed:
Script100.groovy: 5: unable to resolve class com.atlassian.bitbucket.scm.pull.MergeRequestCheck
 @ line 5, column 1.
Script100.groovy: 6: unable to resolve class com.atlassian.bitbucket.scm.pull.MergeRequestCheckContext
 @ line 6, column 1.
Script100.groovy: 7: unable to resolve class com.atlassian.bitbucket.scm.pull.MergeRequestCheckResult
 @ line 7, column 1.
3 errors
Dmitry Trubin
March 23, 2023
https://docs.atlassian.com/bitbucket-server/javadoc/5.7.0/spi/reference/com/atlassian/bitbucket/scm/pull/MergeRequestCheck.html
This interface is deprecated.
in 5.0 for removal in 6.0.
You are likely using Bitbucket of version higher than 6.0.
Refer to the documentation for the respective classes to find a replacement.
Hi @Pavan Kumar Nayakanti
As @Dmitry Trubin already said, some of these classes are deprecated and you will not be able to use them with bitbucket 6 or higher. Currently, ScriprRunner for bitbucket supports Bitbucket server 7.5.0 or higher.
Scriptrunner's merge checks will give you access to a 'mergeRequest' object, which you can use to access any merge-request-related information you need to apply your merge check logic.
I can help you further, if you let me know what kind of merge check you want to do.
atlassian, forge, forge learning path, atlassian learning, cloud app development, forge app development, build forge apps, atlassian certification, developer training, jira app development, confluence app development, automation, ui frameworks
Turn Ideas into Atlassian Apps 📱
From setup to deployment—this learning path shows you how to build your first app using Forge. Learn the essentials, streamline workflows, and bring custom solutions to life across Jira, Confluence, and more.
Start Learning
