Search dosen't work at Bitbucket
netconomyadmin April 20, 2018
It looks like Elasticsearch dosent't work after upgrade from 5.3.1 to 5.9.1.
We have restart the Server often.
The config is the same.
Please help
Lonnie
April 20, 2018
Hello Team, When you upgraded your Bitbucket from  5.3.1 to 5.9.1. You also ended up upgrading your Elasticsearch too from 2.3 to 5.5. This means everything needs to be reindexed. Depending on the size of your environment it may take some time.
Having said that is could be that Elasticsearch isn't started or you are unable to connect to it. Go the Cog in the upper righthand corner > Administration > Server Settings. Find the Search section and click the test button to see if you are able to connect. If so then I suspect it what I mentioned above if not then we need to check if Elasticsearch is staring.
We can look for the process an see if it's running:
ps -ef | grep java
This will list all the java processes and you can see if one of them is Elasticsearch. If you don't see then you need to try and start it:
https://confluence.atlassian.com/bitbucketserver/starting-and-stopping-bitbucket-server-776640144.html
If it is started and you see the process then you need to make sure you can access the URL defined in the server settings. If on the server you can just paste the URL browser.
If your not I would try to telnet to the server @  port
telnet <bitbucketServer> 7992
This should connect if not then your port is blocked either by a firewall or another process.
You can find out by running:
netstat -a
and look for the port and see if it is listening
Hope this help, Feel free to come back with questions
Lonnie
netconomyadmin April 23, 2018
Hello Lonnie,
thx for the fast answer.
I have found the problem, the elasticsearch service did not start.
But the elasticsearch service should be start automatically, when i run start-bitbucket.sh but it dosen't start.
I'm starting bitbucket like this:
systemctl start bitbucket.service
This is my systemctl entry for bitbucket:
#!/usr/bin/env bash
# Resolve any links in $0 to get the real path
[Unit]
Description=Atlassian Bitbucket Server Service
After=syslog.target network.target
[Service]
Type=forking
User=atlbitbucket
ExecStart=/opt/atlassian/bitbucket/atlassian-bitbucket-5.9.1/bin/start-bitbucket.sh
ExecStop=/opt/atlassian/bitbucket/atlassian-bitbucket-5.9.1/bin/stop-bitbucket.sh
[Install]
WantedBy=multi-user.target#
Do you have a idea why the bitbucket servcice starts but not the elasticsearch service?
Kind regards
Matthias
InnoGames GmbH April 23, 2018
We had the same problem.
In your Bitbucket_Home folder,  you can find the following folder:
log/search
and the file:  bitbucket_search.log
If you start Bitbucket, please watch this logfile, if you get the following message, you have the same problem as us:
[2] bootstrap checks failed
[1]: max file descriptors [4096] for elasticsearch process is too low, increase to at least [65536]
[2]: max virtual memory areas vm.max_map_count [65530] is too low, increase to at least [262144]
## Fix for max file descriptors :
https://www.elastic.co/guide/en/elasticsearch/reference/current/file-descriptors.html
Please change or add the following values:
bitbucket           soft    nofile          65536
bitbucket           hard    nofile          65536
in this file:
/etc/security/limits.conf
## Fix for max virtual memory areas
https://www.elastic.co/guide/en/elasticsearch/reference/current/docker.html#docker-cli-run-prod-mode
sysctl -w vm.max_map_count=262144
and so that it will be loaded after the reboot.
paste the value:
into the following file :
/etc/sysctl.conf
Best regards
Felix
netconomyadmin April 24, 2018
Hi Felix,
thx for the detailed answer, but this is not our problem. There are no logs in bitbucket_search.log if i start bitbucket.
If i start bitbucket with systemctl start bitbucket.service, only one processes start which i see if i type ps -ef | grep java.
atlbitb+ 20181     1 99 16:57 ?        00:00:09 /usr/lib/jvm/jdk-8-oracle-x64//bin/java -classpath /opt/atlassian/bitbucket/atlassian-bitbucket-5.9.1/app -Datlassian.standalone=BITBUCKET -Dbitbucket.home=/var/atlassian/application-data/bitbucket -Dbitbucket.install=/opt/atlassian/bitbucket/atlassian-bitbucket-5.9.1 -Xms512m -Xmx1g -XX:+UseG1GC -Dfile.encoding=UTF-8 -Dsun.jnu.encoding=UTF-8 -Djava.io.tmpdir=/var/atlassian/application-data/bitbucket/tmp -Djava.library.path=/opt/atlassian/bitbucket/atlassian-bitbucket-5.9.1/lib/native;/var/atlassian/application-data/bitbucket/lib/native com.atlassian.bitbucket.internal.launcher.BitbucketServerLauncher start
If i start start-bitbucket.sh with the user atlbitbucket i get both processes and elasticsearch works.
atlbitb+ 14520 1 5 16:45 pts/0 00:00:27 /usr/lib/jvm/jdk-8-oracle-x64//bin/java -Xms1g -Xmx1g -XX:+UseConcMarkSweepGC -XX:CMSInitiatingOccupancyFraction=75 -XX:+UseCMSInitiatingOccupancyOnly -XX:+AlwaysPreTouch -Xss320k -Djava.awt.headless=true -Dfile.encoding=UTF-8 -Djna.nosys=true -Djdk.io.permissionsUseCanonicalPath=true -Dio.netty.noUnsafe=true -Dio.netty.noKeySetOptimization=true -Dio.netty.recycler.maxCapacityPerThread=0 -Dlog4j.shutdownHookEnabled=false -Dlog4j2.disable.jmx=true -Dlog4j.skipJansi=true -Dpath.conf=/var/atlassian/application-data/bitbucket/shared/search -Des.path.home=/opt/atlassian/bitbucket/atlassian-bitbucket-5.9.1/elasticsearch -cp /opt/atlassian/bitbucket/atlassian-bitbucket-5.9.1/elasticsearch/lib/* org.elasticsearch.bootstrap.Elasticsearch -d -p /var/atlassian/application-data/bitbucket/log/search/elasticsearch.pid -Epath.conf=/var/atlassian/application-data/bitbucket/shared/search
atlbitb+ 14537 1 30 16:45 pts/0 00:02:43 /usr/lib/jvm/jdk-8-oracle-x64//jre/bin/java -classpath /opt/atlassian/bitbucket/atlassian-bitbucket-5.9.1/app -Datlassian.standalone=BITBUCKET -Dbitbucket.home=/var/atlassian/application-data/bitbucket -Dbitbucket.install=/opt/atlassian/bitbucket/atlassian-bitbucket-5.9.1 -Xms512m -Xmx1g -XX:+UseG1GC -Dfile.encoding=UTF-8 -Dsun.jnu.encoding=UTF-8 -Djava.io.tmpdir=/var/atlassian/application-data/bitbucket/tmp -Djava.library.path=/opt/atlassian/bitbucket/atlassian-bitbucket-5.9.1/lib/native;/var/atlassian/application-data/bitbucket/lib/native com.atlassian.bitbucket.internal.launcher.BitbucketServerLauncher start
Do you have a idea why the elasticsearch process didn't start when i start bitbucket over systemctl?
Kind regards
Matthias
Lonnie
April 24, 2018
So systemctl uses the start up script in /etc/init.d
you need to make sure that script is set up to start both like the script in the installation/bin folder
This should point you in the right direction:
https://confluence.atlassian.com/bitbucketserver/starting-and-stopping-bitbucket-server-776640144.html#StartingandstoppingBitbucketServer-Start/stopBitbucketServerwhenrunningasaservice
I
I have install the script in /etc/systemd/system/
and this script only starts start-bitbucket.sh
The script looks like this:
#!/usr/bin/env bash
[Unit]
[Service]
Type=forking
User=atlbitbucket
ExecStart=/opt/atlassian/bitbucket/atlassian-bitbucket-5.9.1/bin/start-bitbucket .sh
ExecStop=/opt/atlassian/bitbucket/atlassian-bitbucket-5.9.1/bin/stop-bitbucket.s h
[Install]
With older versions it works fine but now we have those problems and i don't know why.
It is possible to start elasticsearch manuell?
Kind regards
Matthias
atlassian, bitbucket, ci/cd workflows, scale ci cd, bitbucket webinar, devops pipeline, continuous integration, continuous delivery, atlassian learning, software automation, developer tools, build and deploy, pipeline optimization, atlassian community
Scale CI/CD workflows faster with Bitbucket Pipelines 🪣
Join this webinar on June 25/26th to learn how to build secure CI/CD workflows using Bitbucket Pipelines and get tips from our own engineers on how to speed up builds and operate at scale.
Register today
