Setting base url for Bitbucket access via SSH
Vishnu V Potti June 25, 2018 edited
I am referencing below link and trying to set base path for HTTP and SSH in Bitbucket.
https://confluence.atlassian.com/bitbucketserver/moving-bitbucket-server-to-a-different-context-path-776640153.html
Background : We are upgrading bitbucket and getting bitbucket up via docker containers. We will be running on 2-3 containers and then using Netscaler to loadbalance.
So we are planning to have a url like https://entloginpage.domain.com/bitbucket for HTTP. There are other applications running on  https://entloginpage.domain.com with different contexts.
So I set Base url in bitbucket as https://entloginpage.domain.com/bitbucket.
Now for SSH, I read that we cannot have context and documentation says "SSH operations occur without the context path at ssh://my-bitbucket-hostname:7999."
Since bitbucket will be running on multiple containers, how this will work. I dont want the users to get containerhost specific ssh urls and instead want them to go through entloginpage.domain.com if possible.
Please let me know .
Vishnu
Edward
July 4, 2018
Hi @Vishnu V Potti,
Using Clustering from Bitbucket Data Center you can join multiple nodes to the cluster. With the Bitbucket Data Center requirements, the load balancer will handle which node(server) gets the SSH request.
Because the load balancer acts similar to a proxy, the steps outlined at Enabling SSH access to Git repositories when running Bitbucket Server behind a proxy and Setting up SSH port forwarding should be followed. This will let you setup the load balancer to handle ssh requests through entloginpage.domain.com. If you have multiple SSH services other than Bitbucket under this domain, you can change which port the load balancer handles the SSH requests from (See With "Port Forwarding on custom port" below).
After you have set the load balancer up, you can use the example table shown at Enabling SSH access to Git repositories when running Bitbucket Server behind a proxy to configure the SSH base URL:
Without Port Forwarding:
  • SSH base URL: ssh://my-bitbucket-hostname:7999
  • SSH Port: 7999
  • Bitbucket Base URL: https://my-bitbucket-hostname
  • Resulting SSH Repository URL: ssh://git@my-bitbucket-hostname:7999/<projectname>/<reponame>.git
With Port Forwarding on default ports:
  • SSH base URL: ssh://entloginpage.domain.com
  • SSH Port: 7999
  • Resulting SSH Repository URL: ssh://git@entloginpage.domain.com/<projectname>/<reponame>.git
With Port Forwarding on custom port 44:
  • SSH base URL: ssh://entloginpage.domain.com:44
  • SSH Port: 7999
  • Resulting SSH Repository URL: ssh://git@entloginpage.domain.com:44/<projectname>/<reponame>.git
Edward
Craig Castle-Mead
June 25, 2018
Hey Vishnu,
Just taking a guess here, but on your load balancer i would expect you can set your 7999 listener to forward to 7999 on your containers.
CCM
atlassian, forge, forge learning path, atlassian learning, cloud app development, forge app development, build forge apps, atlassian certification, developer training, jira app development, confluence app development, automation, ui frameworks
Turn Ideas into Atlassian Apps 📱
From setup to deployment—this learning path shows you how to build your first app using Forge. Learn the essentials, streamline workflows, and bring custom solutions to life across Jira, Confluence, and more.
Start Learning
