Something Went Wrong
Aazib gandhi
August 20, 2018
While updating bitbucket pipeline files, I am getting this error.
cakoster March 21, 2019 edited
I'm getting this. Great error message!
First time I've ever tried to use Bitbucket Pipelines. I think I'll go back to Bamboo or Jenkins.
EDIT: As others have pointed out in https://community.atlassian.com/t5/Bitbucket-questions/Problem-with-Bitbucket-pipelines/qaq-p/794245 , this happens when you don't have write permissions to the master branch of the repo.
Why does this CI tool require direct write access to the master branch of the repo? Why is this not mentioned in the documentation, and why is the error message so meaningless?
Philip Hodder
August 21, 2018
Hi Aazib,
Is this still occurring for you? Bitbucket was encountering a high error rate yesterday, which may have affected you.
Details are here: https://status.bitbucket.org/incidents/x2bdsx6v7l9z
Phil
Aazib gandhi
August 21, 2018
Yes, I am facing this issue and this has nothing to do with yesterday's high error rate.
Aazib
Philip Hodder
August 21, 2018
Hi Aazib,
If this is still an issue for you and causing you issues, you can open a support case here for further investigation: https://support.atlassian.com/contact/#/
Phil
