SourceTree diff between two commits
bhuwan agarwal
February 20, 2014
I am a newbie using Git and SourceTree. I would like to understand how can I use SourceTree to view differences between two different commits. The two commits can be on the same branch or on different branches.
Also explanation of diff parent vs diff merge in the diff view.
5 votes
Y
August 7, 2018
Here is a much better solution :
From the "Log / History" tab, select the two commits ( Ctrl + left click ) and will siply display the diff
Hope that helps
Carlo Marasco
August 8, 2018
Legend, so simple
Deleted user March 20, 2019 edited
This approach works to display the differences, I would like to produce an annotated report, a document or file, in the end, itemizing the changes by file. It would also be nice to attribute the change by commit and by the author.
wangdu1005 May 19, 2019
you are my angle
Antoine Cœur June 4, 2014
Diff vs parent: the diff with the previous commit in the same (HEAD) branch
Diff vs merged: the diff with the previous commit in the other (merged) branch
By Z February 24, 2015
Where is the option in SourceTree? I hightlighted two separate commit and I don't see any option to do that. Thanks.
a7madgamal August 5, 2015
I have the same question!
Antoine Cœur August 5, 2015
1. From one commit, right-click the other commit and select Merge... 2. Untick "Commit merged changed immediately". 3. Compare using Diff vs parent and Diff vs merged. 4. When you are happy, right-click on "Working Copy", select Reset..., select Reset All, click Reset All
Diff vs parent and Diff vs merged are available after a Merge, when selecting a file and clicking the "settings-like" button which is right from the search bar on top right of the diff.
thanks a lot for your answer But I think it should be easier and less risky than this simply selecting the 2 commits right clicking and Diff or something!
Get Certified! ✍️
