I try to connect to our Stash with my Sourcetree, but it says the authentication failed. My username & password are correct though!
It says:
The following errors were encountered:
Authentication failed for Stash with username [my username] - please check your account settings.
Any ideas? Or is this a (known) bug?
I am having the same issue. The URL is coirrect the username and password are correct as I use it everyday. In the edit hosting account I hae selected stash, entered the internal URL which I access via a browser without any issues, entered my username
Went to 1.6.15 SourceTree beta hoping this Authenticate error would go away. It wants to authenticate every 10 minutes. Very annoying.
Still an issue for me, I'm on 1.9.10.0 of SourceTree now. I'd understand if this was someone else's product, but Stash is their own product. You'd think the integration between their own products wouldn't be an issue.
Anyone coming across this thread, being on version 1.6.24 of SourceTree, this version also has a similar bug that was raised here: https://jira.atlassian.com/browse/SRCTREEWIN-3944
Hi Karim,
Did you have any luck figuring out what was the problem? If you get stuck please don't hestitate to raise a support ticket so we can help you further.
Charles
