Sourcetree: git svn fetch from SVN repo
13m2 June 25, 2014
I am trying to access a SVN repo from within Sourctree, so that I can keep a git branch in sync with the svn repo, like so: http://ironymark.diwan.com/2011/04/a-safe-way-to-keep-a-github-and-svn-repository-in-sync/
From the admin of the SVN repo I received a certificate. I can access the repo from a browser (where I added the certificate) and from Cornerstone, a SVN client.
I added the remote repo in Sourcetree. If try to fetch the remote from Sourcetree, I get the following
git -c diff.mnemonicprefix=false -c core.quotepath=false -c credential.helper=sourcetree fetch myproject
fatal: unable to access 'https://example.com/svn/projects/myproject/': The requested URL returned error: 403
Completed with errors, see above
I tried a
git svn fetch
from the terminal window, and I got this reply:
Client certificate filename:
Typing in the certificate filename gives no result, the terminal keeps asking for the certificate filename
The certificate is in the keychain, I checked that.
Or should it be placed in a different location?
Git version is 1.9.2 (System) and 1.8.4.2 (embedded)
Tried both versions, makes no difference.
SVN is version 1.7.10
So,
What could this be and how could I solve this?
13m2 June 26, 2014
OK, found it. When prompted for the certificate filename, you'll need to provide the full path.
From then on it works.
Cheers!
atlassian, compass, developer experience, devex, platform engineering, internal developer platform, component catalog, atlassian learning, productivity tools, developer productivity, software architecture, compass webinar, engineering teams
Discover how Compass drives DevEx and productivity at Atlassian 🏃🏻‍♂️
Learn why Compass was built to tackle dev experience at scale. See how Atlassian uses it to boost visibility, reduce cognitive load, and drive consistency—plus tips to get started and customize your IDP for stronger team engagement.
Join the webinar ✨
