SpringMVC dispatcher [springMvc] could not be started [SOLVED]
blacky1707 January 31, 2021 edited
After updating my linux machine from Ubuntu 19.04 to 20.04.2 LTS Bitbucket is not starting anymore - JIRA is running as expected. Mysql 8.0 is running as DB backend. Im using
mysql-connector-java-8.0.23
This is what the log says:
2021-01-31 01:00:51,014 INFO  [main]  c.a.b.i.b.BitbucketServerApplication No active profile set, falling back to default profiles: default
2021-01-31 01:00:51,846 INFO  [main]  c.a.b.i.boot.log.BuildInfoLogger Starting Bitbucket 7.9.1 (738dc90 built on Thu Jan 14 05:37:14 CET 2021)
2021-01-31 01:00:51,846 INFO  [main]  c.a.b.i.boot.log.BuildInfoLogger JVM: AdoptOpenJDK OpenJDK 64-Bit Server VM 1.8.0_275-b01
2021-01-31 01:00:52,956 INFO  [main]  c.a.b.i.b.BitbucketServerApplication Started BitbucketServerApplication in 3.116 seconds (JVM running for 3.645)
2021-01-31 01:00:56,064 INFO  [spring-startup]  c.a.s.internal.home.HomeLockAcquirer Successfully acquired lock on home directory /var/data/bitbucket
2021-01-31 01:00:57,063 WARN  [spring-startup]  c.z.hikari.util.DriverDataSource Registered driver with driverClassName=com.mysql.jdbc.Driver was not found, trying direct instantiation.
2021-01-31 01:00:59,200 WARN  [spring-startup]  o.s.w.c.s.XmlWebApplicationContext Exception encountered during context initialization - cancelling refresh attempt: org.springframework.beans.factory.UnsatisfiedDependencyException: Error creating bean with name 'crowdAliasDao': Unsatisfied dependency expressed through method 'setSessionFactory' parameter 0; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'sharedHomeLockAcquirer' defined in class path resource [stash-context.xml]: Cannot resolve reference to bean 'licenseHelper' while setting constructor argument; nested exception is org.springframework.beans.factory.UnsatisfiedDependencyException: Error creating bean with name 'licenseHelper' defined in URL [jar:file:/var/bitbucket/app/WEB-INF/lib/bitbucket-service-impl-7.9.1.jar!/com/atlassian/stash/internal/license/DefaultLicenseHelper.class]: Unsatisfied dependency expressed through constructor parameter 2; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'bootstrapLiquibase' defined in class path resource [stash-context.xml]: Invocation of init method failed; nested exception is java.lang.ClassCastException: java.time.LocalDateTime cannot be cast to java.lang.String
2021-01-31 01:00:59,206 INFO  [spring-startup]  c.a.s.internal.home.HomeLockAcquirer Releasing lock on /var/data/bitbucket
2021-01-31 01:00:59,211 ERROR [spring-startup]  c.a.j.s.w.s.JohnsonDispatcherServlet SpringMVC dispatcher [springMvc] could not be started
at org.springframework.beans.factory.annotation.AutowiredAnnotationBeanPostProcessor$AutowiredMethodElement.inject(AutowiredAnnotationBeanPostProcessor.java:723)
at org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:879)
at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:551)
at javax.servlet.GenericServlet.init(GenericServlet.java:158)
at java.lang.Thread.run(Thread.java:748)
... 18 frames trimmed
Caused by: org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'sharedHomeLockAcquirer' defined in class path resource [stash-context.xml]: Cannot resolve reference to bean 'licenseHelper' while setting constructor argument; nested exception is org.springframework.beans.factory.UnsatisfiedDependencyException: Error creating bean with name 'licenseHelper' defined in URL [jar:file:/var/bitbucket/app/WEB-INF/lib/bitbucket-service-impl-7.9.1.jar!/com/atlassian/stash/internal/license/DefaultLicenseHelper.class]: Unsatisfied dependency expressed through constructor parameter 2; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'bootstrapLiquibase' defined in class path resource [stash-context.xml]: Invocation of init method failed; nested exception is java.lang.ClassCastException: java.time.LocalDateTime cannot be cast to java.lang.String
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:342)
... 5 common frames omitted
Caused by: org.springframework.beans.factory.UnsatisfiedDependencyException: Error creating bean with name 'licenseHelper' defined in URL [jar:file:/var/bitbucket/app/WEB-INF/lib/bitbucket-service-impl-7.9.1.jar!/com/atlassian/stash/internal/license/DefaultLicenseHelper.class]: Unsatisfied dependency expressed through constructor parameter 2; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'bootstrapLiquibase' defined in class path resource [stash-context.xml]: Invocation of init method failed; nested exception is java.lang.ClassCastException: java.time.LocalDateTime cannot be cast to java.lang.String
at org.springframework.beans.factory.support.ConstructorResolver.createArgumentArray(ConstructorResolver.java:797)
Caused by: org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'bootstrapLiquibase' defined in class path resource [stash-context.xml]: Invocation of init method failed; nested exception is java.lang.ClassCastException: java.time.LocalDateTime cannot be cast to java.lang.String
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1794)
Caused by: java.lang.ClassCastException: java.time.LocalDateTime cannot be cast to java.lang.String
at liquibase.changelog.StandardChangeLogHistoryService.getRanChangeSets(StandardChangeLogHistoryService.java:324)
at liquibase.changelog.AbstractChangeLogHistoryService.upgradeChecksums(AbstractChangeLogHistoryService.java:66)
at liquibase.changelog.StandardChangeLogHistoryService.upgradeChecksums(StandardChangeLogHistoryService.java:293)
at liquibase.Liquibase.checkLiquibaseTables(Liquibase.java:1221)
at liquibase.Liquibase.update(Liquibase.java:193)
at liquibase.Liquibase.update(Liquibase.java:179)
at liquibase.integration.spring.SpringLiquibase.performUpdate(SpringLiquibase.java:317)
at liquibase.database.ExtendedSpringLiquibase.afterPropertiesSet(ExtendedSpringLiquibase.java:39)
yipsilon February 1, 2021
I also get this error after upgrade bitbucket from 7.0.1 to 7.9.1.
blacky1707 February 1, 2021
It worked before with 7.9.1 on Ubuntu 19.04 - so I guess the version is not the issue. On which OS are you running Bitbucket?
yipsilon February 2, 2021
Windows Server 2019
blacky1707 February 2, 2021
Ok. Seems not to be related. Funny thing is, that a vanilla installation works as expected, so I guess it's somehow related to the data stored in the database. I even restored different older versions of the DB and the data files, with the same result.
Really strange and frustrating, that there is no support from Atlassian side in this case (there are several similar cases in this forum).
yipsilon February 3, 2021
I find the solution!
Bitbucket server does not support Conector/J 8.0.
It only supports 5.1.
After I replace the jdbc driver to version 5.1.49, it is resolved.
Like • 2 people like this
blacky1707 February 3, 2021
Works like a charm :-)
SERVER
VERSION
7.9.1
