Hi all,
I am facing the following issue:
ERROR [spring-startup] c.a.j.s.w.s.JohnsonDispatcherServlet SpringMVC dispatcher [springMvc] could not be started
org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'gitBundledResources' defined in com.atlassian.stash.internal.scm.git.GitWiring: Invocation of init method failed; nested exception is java.io.IOException: Mount point not found
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1630)
at org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:867)
at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:543)
at javax.servlet.GenericServlet.init(GenericServlet.java:158)
at java.lang.Thread.run(Thread.java:748)
... 17 frames trimmed
Caused by: java.io.IOException: Mount point not found
at sun.nio.fs.LinuxFileStore.findMountEntry(LinuxFileStore.java:91)
at sun.nio.fs.UnixFileStore.<init>(UnixFileStore.java:65)
at sun.nio.fs.LinuxFileStore.<init>(LinuxFileStore.java:44)
at sun.nio.fs.LinuxFileSystemProvider.getFileStore(LinuxFileSystemProvider.java:51)
at sun.nio.fs.LinuxFileSystemProvider.getFileStore(LinuxFileSystemProvider.java:39)
at sun.nio.fs.UnixFileSystemProvider.getFileStore(UnixFileSystemProvider.java:368)
at java.nio.file.Files.getFileStore(Files.java:1461)
at com.atlassian.stash.internal.scm.git.BundledResources.isPosixFilesystem(BundledResources.java:103)
at com.atlassian.stash.internal.scm.git.BundledResources.installScript(BundledResources.java:89)
at com.atlassian.stash.internal.scm.git.BundledResources.unpack(BundledResources.java:36)
... 5 common frames omitted
Do you have any idea on what went wrong and how to check which mount point it is trying to use?
We have the same issue.
We are running the Teams in Space environment for presentations. All application were working fine, but after restart, bitbucket won't start with the same error message as above.
Same here, reinstalled and tried a new machine, all versions of 6.3 have this problem, 2 is fine
I too have the same issue SpringMVC dispatcher [springMvc] could not be started
Hi Dennis,
Most likely this is about the shared home directory (inside <BitbucketHome>).
Christian
Premier Support Engineer
Atlassian
Hi Christian,
thanks for the reply. I checked the directory, but for me everything looks fine:
$ ll /var/atlassian/application-data/bitbucket/
total 48
drwxr-xr-x 11 atlbitbucket atlbitbucket 4096 Sep 6 07:57 ./
drwxr-xr-x 3 root root 4096 Sep 6 07:44 ../
drwxr-xr-x 2 atlbitbucket atlbitbucket 4096 Sep 6 07:44 .oracle_jre_usage/
-rw-r--r-- 1 atlbitbucket atlbitbucket 62 Sep 6 07:45 .version
drwxr-xr-x 4 atlbitbucket atlbitbucket 4096 Sep 6 07:48 bin/
drwxr-xr-x 4 atlbitbucket atlbitbucket 4096 Sep 6 07:57 caches/
drwxr-xr-x 2 atlbitbucket atlbitbucket 4096 Sep 6 07:45 export/
drwxr-xr-x 3 atlbitbucket atlbitbucket 4096 Sep 6 07:45 lib/
drwxr-xr-x 4 atlbitbucket atlbitbucket 4096 Sep 10 07:32 log/
drwxr-xr-x 3 atlbitbucket atlbitbucket 4096 Sep 6 07:45 plugins/
drwxr-xr-x 6 atlbitbucket atlbitbucket 4096 Sep 6 07:57 shared/
drwxr-xr-x 6 atlbitbucket atlbitbucket 4096 Sep 6 07:56 tmp/
$ ll /var/atlassian/application-data/bitbucket/shared/
total 24
drwxr-xr-x 6 atlbitbucket atlbitbucket 4096 Sep 6 07:57 ./
drwxr-xr-x 11 atlbitbucket atlbitbucket 4096 Sep 6 07:57 ../
drwxr-xr-x 4 atlbitbucket atlbitbucket 4096 Sep 6 07:48 config/
drwxr-xr-x 7 atlbitbucket atlbitbucket 4096 Sep 6 07:57 data/
drwxr-xr-x 5 atlbitbucket atlbitbucket 4096 Sep 6 07:44 search/
Do you have any idea on why bitbucket cannot access this directory?
