×Error
Unable to fetch from remote repository: http://stash@stash.corp.cox.com:8080/scm/CCVM/cox_csl_repo.git - fatal: http://stash:XXXX@stash.corp.cox.com:8080/scm/CCVM/cox_csl_repo.git/info/refs not valid: is this a git repository?
This error mean what you simple change project key, but also you ignored message from Stash to you. Stash tell to change origin to new one URL. Please check oring within repo and compare to repo URL from web interface of Stash.
git remote -v
Re reason it happened whas because Crucible access was setup to use 'port forwarding', and the IP to identify/refernce it in Stash server was change by mistake. As soon we correct the ip, it works again.
