Unable to join nodes using docker compose
smoesy October 8, 2025
Hi community!
I’m trying to set up Bitbucket using Docker Compose and enable clustering. However, I keep seeing the following message in the logs:
com.hazelcast.instance.impl.Node [172.28.0.11]:5701 [bitbucket-cluster] [5.4.1] No join method is enabled! Starting standalone.
I’ve tried multiple configurations, but Hazelcast always starts in standalone mode. I’m using Docker Compose with 2 Bitbucket instances, on the same host, and I want them to form a cluster.
Has anyone successfully configured Bitbucket clustering in Docker Compose? What settings are required to enable Hazelcast clustering?
This is my compose file:
version: "3.8"
networks:
  bitbucket-net:
    driver: bridge
    ipam:
      config:
        - subnet: 172.28.0.0/16
services:
  postgres:
    image: postgres:16
    container_name: bitbucket-db
    environment:
      POSTGRES_DB: bitbucket-db
      POSTGRES_USER: bitbucket
      POSTGRES_PASSWORD: bitbucket
    volumes:
      - ./pgdata:/var/lib/postgresql/data
    networks:
      - bitbucket-net
  bitbucket-1:
    image: atlassian/bitbucket:latest
    container_name: bitbucket-1
    depends_on:
      - postgres
    environment:
      SEARCH_ENABLED: "false"
      BITBUCKET_CLUSTERED: "true"
      BITBUCKET_SHARED_HOME: /var/atlassian/application-data/bitbucket/shared
      JDBC_DRIVER: org.postgresql.Driver
      JDBC_URL: jdbc:postgresql://bitbucket-db:5432/bitbucket-db?targetServerType=master
      JDBC_USER: bitbucket
      JDBC_PASSWORD: bitbucket
      BITBUCKET_NODE_ID: "node1"
      # Configurare Hazelcast (clustering)
      HAZELCAST_MANAGEMENTSERVER_ENABLED: "true"
      HAZELCAST_PORT: "5701"
      HAZELCAST_GROUP_NAME: "bitbucket-cluster"
      HAZELCAST_GROUP_PASSWORD: "secret123"
      HAZELCAST_NETWORK_INTERFACES: "172.28.0.*"
      HAZELCAST_NETWORK_JOIN_MULTICAST_ENABLED: "false"
      HAZELCAST_NETWORK_JOIN_TCPIP_ENABLED: "true"
      HAZELCAST_NETWORK_TCPIP_MEMBERS: "172.28.0.11:5701,172.28.0.12:5701"
    ports:
      - "7990:7990"
      - "7999:7999"
    volumes:
      - ./bitbucket-home/node1:/var/atlassian/application-data/bitbucket
      - shared-home:/var/atlassian/application-data/bitbucket/shared
    networks:
      bitbucket-net:
        ipv4_address: 172.28.0.11
  bitbucket-2:
    container_name: bitbucket-2
    depends_on:
      - postgres
    environment:
      BITBUCKET_SHARED_HOME: /var/atlassian/shared-home
      BITBUCKET_NODE_ID: "node2"
    ports:
      - "7991:7990"
      - "8000:7999"
    volumes:
      - ./bitbucket-home/node2:/var/atlassian/application-data/bitbucket
    networks:
      bitbucket-net:
        ipv4_address: 172.28.0.12
volumes:
  shared-home:
    driver_opts:
      type: "nfs"
      o: "addr=192.168.20.193,nolock,soft,rw"
      device: ":/srv/bitbucket/shared-home"
Solved this. Worked if switched from hazelcast tcp ip to multicast. This answer was helpful if anyone else runs into this issue: https://stackoverflow.com/questions/55863657/how-to-start-bitbucket-server-as-a-container-in-detached-mode
