Unknown state in response
esk March 8, 2020 edited
We're trying to setup SSO on our Bitbucket DC instance with OIDC and we're seeing this error after logging in on our IDp(Keycloak).
com.atlassian.plugins.authentication.impl.web.usercontext.AuthenticationFailedException: Unknown state in response
Does anymore have more info on the error?
The stack trace is
	at com.atlassian.plugins.authentication.impl.web.oidc.OidcConsumerServlet.lambda$doGet$0(OidcConsumerServlet.java:103)
	at java.base/java.util.Optional.orElseThrow(Optional.java:408)
	at com.atlassian.plugins.authentication.impl.web.oidc.OidcConsumerServlet.doGet(OidcConsumerServlet.java:103)
	at javax.servlet.http.HttpServlet.service(HttpServlet.java:634)
	at javax.servlet.http.HttpServlet.service(HttpServlet.java:741)
	at com.atlassian.plugin.servlet.DelegatingPluginServlet.service(DelegatingPluginServlet.java:37)
	at com.atlassian.plugin.servlet.ServletModuleContainerServlet.service(ServletModuleContainerServlet.java:46)
Joe Red
I am getting this error after a user as already been into the application. Now they cannot get in and the logs are saying Unknown State in Response.
Any help?
Laurent s
November 9, 2021
hi
i've got same problem with confluence and Cas Apero OIDC. I'm not sure what to write in "username claim"
i try with {sub} or {id} or something else, and i"ve always the same error
a solution for someone ?
Reab May 3, 2021
@esk I'm facing this issue, were you able to solve it?
Gonchik Tsymzhitov
Hi!
Have you tried to clean config and do it from scratch?
Reab April 20, 2021
Hi. Which config to clean?
