Sign up Log in
Upgrade to 2.0.1 from 1.3 - Very slow push (>20 seconds)
Thomas Solbjør January 16, 2013
I had another issue with Stash after upgrading (SSP-548) and I was hoping that by fixing that I also got rid of this issue - but I still have the problem.
Excerpt from the logs (profiler):
{code}
141ms - GET /scm/TEST/foo.git/info/refs HTTP/1.1
141ms - StashUser com.atlassian.stash.user.UserService.authenticate(String,String,CaptchaResponse)
0ms - Object com.atlassian.stash.user.SecurityService.doWithPermission(String,Permission,Operation)
0ms - Repository com.atlassian.stash.repository.RepositoryService.findBySlug(String,String)
0ms - InternalRepository com.atlassian.stash.internal.repository.RepositoryDao.findBySlugAndProjectKey(String,String)
0ms - boolean com.atlassian.stash.user.PermissionService.hasRepositoryPermission(StashUser,Repository,Permission)
2013-01-17 09:48:31,971 http-apr-7990-exec-6 thomas
172ms - GET /scm/TEST/foo.git/info/refs HTTP/1.1
0ms - InternalStashUser com.atlassian.stash.internal.user.StashUserDao.findByName(String)
0ms - void com.atlassian.stash.internal.user.RepositoryAccessDao.trimToFirstPage(InternalStashUser,int,Predicate)
0ms - boolean com.atlassian.stash.internal.user.GrantedPermissionDao.isGrantedToUser(UserPermissionSearchCriteria)
0ms - Integer com.atlassian.stash.internal.user.StashUserDao.findIdByName(String)
0ms - boolean com.atlassian.stash.user.PermissionService.hasGlobalPermission(StashUser,Permission)
0ms - Page com.atlassian.stash.user.UserService.findGroupsByUser(String,PageRequest)
0ms - Map com.atlassian.stash.internal.user.GrantedPermissionDao.mapPermissionsByProject(Integer,Set)
0ms - boolean com.atlassian.stash.scm.ScmRequestCheckService.checkActionAllowed(ScmRequest)
0ms - boolean com.atlassian.stash.license.LicenseService.canLogin(Principal)
0ms - boolean com.atlassian.stash.user.PermissionService.hasRepositoryPermission(Repository,Permission)
0ms - Ticket com.atlassian.stash.throttle.ThrottleService.acquireTicket(String)
31ms - C: Program Files (x86) Git bin git.exe http-backend
33391ms - POST /scm/TEST/foo.git/git-receive-pack HTTP/1.1
203ms - StashUser com.atlassian.stash.user.UserService.authenticate(String,String,CaptchaResponse)
15ms - Integer com.atlassian.stash.internal.user.StashUserDao.findIdByName(String)
33188ms - C: Program Files (x86) Git bin git.exe http-backend
{code}
After installing Stash as a Windows Service (https://confluence.atlassian.com/display/STASH/Running+Stash+as+a+Windows+service) the "Atlassian Stash" service runs as "Local System". This is turn executes git.exe as Administrator which makes "push" slow.
By changing the user who runs the "Atlassian Stash" service to a local Windows user (without Administrator rights) pushing is fast again.
Daniel R
April 22, 2013
Hello Thomas,
We've written this KB article:
Git Push Operations Extremely Slow on Windows
