We want to add Due Date/Labels based on the JIRA issue date fields?
Hi there,
The Global Pull Request Organizr is a recent submission we are still working on publishing its REST Api documentation.
For now please use the following
Labels
POST http://host:7990[/bitbucket]/rest/organizr/latest/labels/projKey/repoSlug/pullrequestId Payload JSON { labels: ['label_a', 'label_b'] }
For DELETE and GET use the same URL
Due Dates
POST http://host:7990[/bitbucket]/rest/organizr/latest/meta/duedate/projKey/repoSlug/pullrequestId Payload JSON { duedate: due_date_in_seconds_unix_timestamp] }
hi! one problem with rest api call to organizr is that when you trying to Delete a label it deletes all the labels on the PR. If you post a new label and there is existing label on the PR, new label will replace existing label on the PR, so you will loose all your old labels.
