What could cause this error when running a build in bitbucket pipelines?
Robb Gosset June 27, 2017
So I've been setting up an automated build for some embedded code I'm working on, the final stage of the build process (for each built hex file) is a step where curl uploads it to the downloads page of the Bitbucket repo, I have the same step working in 2 other repositories and in the previous steps for another hex file in the same repo/config file. What could be causing this error to come up?
+ curl -X POST --user "${BB_AUTH_STRING}" "https://api.bitbucket.org/2.0/repositories/${BITBUCKET_REPO_OWNER}/${BITBUCKET_REPO_SLUG}/downloads" --form files=@"../release/rdmIntergratedDriver-$(git describe --long --tags --always --dirty)-$(git rev-parse --abbrev-ref HEAD | cut -f 1- -d/ | sed "s/\//-/").hex
bash: /opt/atlassian/pipelines/agent/tmp/bashScript7120016009615084851.sh: line 39: syntax error near unexpected token `('
 Here's an example from earlier in the same build where another hex file is uploaded successfully:
+ curl -X POST --user "${BB_AUTH_STRING}" "https://api.bitbucket.org/2.0/repositories/${BITBUCKET_REPO_OWNER}/${BITBUCKET_REPO_SLUG}/downloads" --form files=@"../release/D48-controller-$(git describe --long --tags --always --dirty)-$(git rev-parse --abbrev-ref HEAD | cut -f 1- -d/ | sed "s/\//-/").hex"
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0
100 105k 0 0 100 105k 0 443k --:--:-- --:--:-- --:--:-- 443k
atlassian, atlassian community, job interviews, interview tips, career advice, interview preparation, job search, interview experiences, hiring process, atlassian careers, community discussion, interview best practices
Interview Tips & Pet Peeves ✍️
Join the discussion on interview best practices and common pitfalls. Share your experiences and learn from others in the Atlassian Community.
Share you experiences!
