×What is the difference of these parameters.
plugin.search.config.baseurl=<search server URL> #e.g. http://localhost:9200/
plugin.search.config.username=<username> #e.g. bitbucket
plugin.search.config.password=<password> #e.g. the password that was hashed
plugin.search.search.baseurl=
plugin.search.search.username=
plugin.search.search.password=
The Opensearch installation page has given the first set of parameters
Change password page has given the 2nd set of parameters.
Both are same ?
Hi Asarudeen,
Thanks for pointing this out! The correct parameters are
I've updated the page at https://confluence.atlassian.com/bitbucketserverkb/troubleshooting-steps-for-bitbucket-server-code-search-827125334.html?_cachebust=2446057267 with the correct parameters, if you found incorrect ones anywhere else please let me know and I'll get that updated too.
Christian
Premier Support Engineer
Atlassian
Hi Asarudeen,
Thanks for letting us know, I've submitted a documentation bug for this, which should get picked up and fixed soon.
Christian
Atlassian
