What's the Path to Downloads? (For Maven settings.xml)
walkerca October 4, 2018
I've uploaded a settings.xml file to the repository Downloads area.  I'd like to specify that with a -s option in a Pipeline.  There's a post recommending a cp command to bring the file in the workspace.
Is there an environment variable or path that I can use to find the file?  I get a "no such file" when I try the suggested path (starting w. /opt/atlassian).
https://community.atlassian.com/t5/Bitbucket-questions/settings-xml-configuration-on-Pipelines/qaq-p/167693
Carl
Philip Hodder
October 4, 2018 edited
Hi Carl,
When you say you've uploaded a file to the repository Downloads are. Do you mean the downloads section (listed in the sidebar)?
If so, these aren't copied into your pipelines. Only the repository itself. You need to manually download these. You can have a look a the REST API docs for how to do this: https://developer.atlassian.com/bitbucket/api/2/reference/resource/repositories/%7Busername%7D/%7Brepo_slug%7D/downloads/%7Bfilename%7D
If you don't mean that, can you clarify what you mean by "repository Downloads area"?
Can you also include your bitbucket-pipelines.yml for additional context?
An additional debugging trick you could try is:
ls -Rhl ~ | grep settings.xml # This will check to see if the file exists.
Just for some extra information: There's a default environment variable called BITBUCKET_CLONE_DIR which points at /opt/atlassian/pipelines/agent/build. However that's the directory you seem to be using already, so don't need to do anything.
Phil
walkerca October 12, 2018 edited
Hi Phil,
Associated with a BitBucket Repository, there is a Downloads tab (your screenshot) which takes you to a Downloads page.  I've uploaded a settings.xml to this page that I would like to use in my build.  I would also like to upload a code signing cert.
I don't want to store the settings.xml or the cert in the repository itself as they contain credentials.
In Jenkins, I'm using "Settings file in filesystem" in the build definition and WebDAV to maintain the artifact.  It sounds like I'll need to issue a curl call prior to issuing any Maven commands in my YAML.
Carl
The REST API suggested by Phil is working for me.  I have my settings.xml file uploaded to Downloads in the Repository (but not checked into the source code).  I'm using masked environment variables to hold the account information needed for the curl: BB_USER, BB_PASS.
My mvn uses the file downloaded in a curl step like this
          - curl --user $BB_USER:$BB_PASS -o settings-demo.xml -L https://api.bitbucket.org/2.0/repositories/MYORG/demo-repo/downloads/settings-demo.xml
          - mvn -B -s settings-demo.xml verify # -B batch mode makes Maven less verbose
