Why can't I make a custom pre-hook in a project
Margaria Vince February 6, 2023
Hello, I am trying to make a custom pre-receive hook but I can't make a custom pre-hook in a project I created, I can only do a custom pre-hook if I am at the base of my BB, making it really difficult to test my pre-hook since a lot of users will be impacted. Is there something I am missing ?
Craig Nodwell
Hi @Margaria Vince you can do this at the Project or even Repository Level.  Go to Admin in the Project then Scriptrunner then Pre-Hooks
Craig Nodwell
Here's a reference for you
Margaria Vince February 7, 2023
Hello, it seems you did not understand my problem so I took a screenshot, whenever I am in a project, I don't have the option to create a custom pre-hook, but If I go to the root (where all the pre-hooks for every project are) I can create a custom pre-hook.
Hi @Margaria Vince
ScriptRunner scripts for Project and Repository level, are running in restricted sandboxed environment, see https://docs.adaptavist.com/sr4bib/latest/get-started/settings/admin-only-project-and-repository-script-access
This also means that some features are only available in a Global level, and cannot be set in a repository or project level, for a full list of these features, you can have a look at https://docs.adaptavist.com/sr4bib/latest/get-started/permissions
atlassian, forge, forge learning path, atlassian learning, cloud app development, forge app development, build forge apps, atlassian certification, developer training, jira app development, confluence app development, automation, ui frameworks
Turn Ideas into Atlassian Apps 📱
From setup to deployment—this learning path shows you how to build your first app using Forge. Learn the essentials, streamline workflows, and bring custom solutions to life across Jira, Confluence, and more.
Start Learning
