Why does zip work differently than composer archive in pipelines?
aberkow
I'm trying to understand why (and how) creating zip files which include composer's vendor directory works differently in pipelines depending on if I use `composer archive` or `zip`.
With the following `bitbucket-pipelines.yml` script, I can successfully create a zip file for my project that includes composer's vendor directory with all of its contents.
develop:
- step:
script:
- composer install --no-dev
- zip -FSr ${BITBUCKET_REPO_SLUG}-develop.zip ./ -x@exclude.lst
- curl -u ${BB_AUTH_STRING} -X POST "https://api.bitbucket.org/2.0/repositories/${BITBUCKET_REPO_OWNER}/${BITBUCKET_REPO_SLUG}/downloads" --form files=@"${BITBUCKET_REPO_SLUG}-develop.zip"
However, if I replace the `zip` command with
composer archive --format=zip --file ${BITBUCKET_REPO_SLUG}-develop
the vendor directory is sometimes either not created at all in the zip file, or it is, but doesn't include any files. There doesn't seem to be any pattern as to why it includes these directories or not.
For reference, my composer.json file includes this
"archive": {
"exclude": [
"*.yml",
"node_modules/",
"www/",
"sass/",
"yarn.lock"
The exclude.lst file includes the same list but with a different syntax.
aberkow
Never mind. The key was to explicitly include the vendor directory and all its contents with
"archive": {
"exclude": [
"!vendor/*" //etc...
atlassian, bitbucket, ci/cd workflows, scale ci cd, bitbucket webinar, devops pipeline, continuous integration, continuous delivery, atlassian learning, software automation, developer tools, build and deploy, pipeline optimization, atlassian community
Scale CI/CD workflows faster with Bitbucket Pipelines 🪣
Join this webinar on June 25/26th to learn how to build secure CI/CD workflows using Bitbucket Pipelines and get tips from our own engineers on how to speed up builds and operate at scale.
Register today
