Win 10 Turkish locale workaround doesn't work
Çağrı Çakır
July 13, 2018
Followed the workaround for the error of
The current locale (T�rk�e (T�rkiye)) is not supported by Bitbucket.
it didnt work.
Screenshots show the ENV_ parameters are set by me.
The error on
http://localhost:7990/unavailable?next=%2F
follows like below:
  • The current locale (T�rk�e (T�rkiye)) is not supported by Bitbucket.
    Please follow the instructions in this knowledge base article to resolve the issue.
  • Required plugin com.atlassian.templaterenderer.api has failed to start
  • Required plugin com.atlassian.bitbucket.server.bitbucket-velocity-helper has failed to start
  • Required plugin com.atlassian.atlassian-failure-cache-plugin has failed to start
  • Required plugin com.atlassian.crowd.embedded.admin has failed to start
  • Required plugin com.atlassian.plugins.atlassian-nav-links-plugin has failed to start
  • Required plugin com.atlassian.templaterenderer.atlassian-template-renderer-velocity1.6-plugin has failed to start
  • Required plugin com.atlassian.oauth.consumer.sal has failed to start
  • Required plugin com.atlassian.bitbucket.server.bitbucket-rest has failed to start
  • Required plugin com.atlassian.bitbucket.server.bitbucket-nav-links has failed to start
  • Required plugin com.atlassian.applinks.applinks-plugin has failed to start
  • Required plugin com.atlassian.troubleshooting.plugin-bitbucket has failed to start
  • Required plugin com.atlassian.plugins.atlassian-plugins-webresource-rest has failed to start
  • Required plugin com.atlassian.auiplugin has failed to start
  • Required plugin com.atlassian.oauth.consumer has failed to start
  • Required plugin com.atlassian.upm.atlassian-universal-plugin-manager-plugin has failed to start
  • Required plugin com.atlassian.soy.soy-template-plugin has failed to start
  • Required plugin com.atlassian.oauth.atlassian-oauth-service-provider-spi has failed to start
  • Required plugin com.atlassian.stash.ssh-plugin has failed to start
  • Required plugin com.atlassian.activeobjects.activeobjects-plugin has failed to start
  • Required plugin com.atlassian.bitbucket.server.bitbucket-sal has failed to start
  • Required plugin com.atlassian.bitbucket.server.bitbucket-crowd-spi has failed to start
  • Required plugin com.atlassian.markup.atlassian-markup-renderer-plugin has failed to start
  • Required plugin com.atlassian.plugins.atlassian-plugins-webresource-plugin has failed to start
  • Required plugin com.atlassian.oauth.serviceprovider.sal has failed to start
  • Required plugin com.atlassian.plugins.atlassian-client-resource has failed to start
  • Required plugin com.atlassian.plugins.less-transformer-plugin has failed to start
  • Required plugin com.atlassian.oauth.serviceprovider has failed to start
  • Required plugin com.atlassian.oauth.admin has failed to start
  • Required plugin com.atlassian.plugins.rest.atlassian-rest-module has failed to start
