Write script output files to repository
Arjan Oskam
I have a Python pipeline where I am running Robotframework on for testing the commit, but I want to be able to save the output files in the repository or somewhere else on a server.
But I have no idea on how to do that
Arjan Oskam
The true solution is to install git and add the pipelines SSH key to your bitbucket account, then you can set some variables and you will be able to commit files and push them to the wanted repository!
Ana Retamal
April 12, 2017
Hi Arjan!
You can follow the steps in the article Deploy build artifacts to Bitbucket Downloads. If you prefer to send the files to another server you can do it with sftp, rsync, git push, etc,... depending on how your workflow works.
Hope this helps :)
atlassian, compass, developer experience, devex, platform engineering, internal developer platform, component catalog, atlassian learning, productivity tools, developer productivity, software architecture, compass webinar, engineering teams
Discover how Compass drives DevEx and productivity at Atlassian 🏃🏻‍♂️
Learn why Compass was built to tackle dev experience at scale. See how Atlassian uses it to boost visibility, reduce cognitive load, and drive consistency—plus tips to get started and customize your IDP for stronger team engagement.
Join the webinar ✨
