Yarn: command not found
Adam Polak
March 16, 2018
Since about 12PM we're receiving an error:
bash: yarn: command not found
We're using default node:8 image
image: node:8
pipelines:
    default:
        - step:
            caches:
                - node
            script:
                - yarn install
                - yarn run flow
                - yarn run build
                - yarn run test --coverage --no-cache
 Does anything changed between 10AM and 12PM - last success build on the same pipelines config was at 10:20AM
Adam Polak
March 18, 2018
For those having the same problem:
We had to change image from
image: node:8
to
image: node:9.7.1
Ramon de Jezus
January 6, 2021
For me it turned out that I accidentally redefined $PATH in bitbucket pipelines environment variables, causing the same message. Took a while to figure it out...
rafawalter
March 26, 2019
Works with
image: node:6.17.0
Philip Hodder
April 2, 2018
Alternatively, for anyone using an image that doesn't have yarn installed you can also install it as part of your build.
For example, add an installation command to your script such as:
- npm install yarn
pablofmorales
June 4, 2018
doesn't work
Miklos Szanyi
July 25, 2018
- npm install -g yarn
Like • 5 people like this
