application.tgz is not uploaded to heroku (using atlassian/heroku-deploy:1.2.1)
Yuriy Okhonin
September 23, 2021
artifact is created and listed on previous step, I can download it to my local machine.
On next step "pipe atlassian/heroku-deploy:1.2.1"
I get the follwoing error:
Traceback (most recent call last):
File "/usr/bin/main.py", line 154, in <module>
File "/usr/bin/main.py", line 74, in run
with open(zip_file, 'rb') as zipfile:
FileNotFoundError: [Errno 2] No such file or directory: 'application.tgz'
Also 'application.tgz' is not listed under 'Artifacts' tab  in my 'Deploy to production' step.
Link to my repository https://bitbucket.org/vihv/stiltsofttestyo (private, but I expect techsupport have access)
Here is my bitbucket-piplines.yml
image: maven:3.6.3
pipelines:
default:
- parallel:
- step:
name: Build and Test
caches:
- maven
script:
- mvn -B verify --file pom.xml
after-script:
- pipe: atlassian/checkstyle-report:0.2.0
- step:
script:
- pipe: atlassian/git-secrets-scan:0.4.3
- step:
script:
- tar czfv application.tgz pom.xml src/
artifacts:
- application.tgz
- step:
name: Deploy to production
deployment: production
script:
- pipe: atlassian/heroku-deploy:1.2.1
variables:
HEROKU_API_KEY: $HEROKU_API_KEY
HEROKU_APP_NAME: $HEROKU_APP_NAME
ZIP_FILE: 'application.tgz'
DEBUG: 'true'
Theodora Boudale
September 27, 2021
Hi Yuriy and welcome to the community!
I believe the culprit here may be that the step that generates the artifact and the step that does the deployment belong in the same parallel set. Parallel steps can only use artifacts produced by previous steps, not by steps in the same parallel set.
What you can do is move the last step out of the parallel set, by changing the indentation two spaces back for that step, as follows:
image: maven:3.6.3
pipelines:
default:
- parallel:
- step:
caches:
- maven
script:
after-script:
- step:
script:
- step:
script:
artifacts:
- application.tgz
- step:
script:
variables:
DEBUG: 'true'
This way, only the first 3 steps are in the same parallel set, and the artifact will be available for the last step.
Please feel free to let me know if this helps and if you have any questions.
Theodora
Alexander Ritterath
November 30, 2021
Thank you Theodora. This was very helpful for me.
Like • Theodora Boudale likes this
Theodora Boudale
December 6, 2021
You are very welcome Alexander, I'm glad that this was helpful!
Like • Getachew Tebkew likes this
Getachew Tebkew
March 27, 2022
saved my life too
Theodora Boudale
March 28, 2022
That's good to hear @Getachew Tebkew!
