We just started using Atlasboard. But apart from the install demo (I have successfully got it running), I can hardly find any tutorial or documentation showing how to create my own widget and job.
Are there any good documentation available? Currently I am wanting Atlasboard to display Stash information, such as number of check-ins and how many things are still waiting for reviewers. I am finding it hard to do anything.
Please help.
Bernard -
I have just started working with this myself. You want the main Atlasboard page at https://bitbucket.org/atlassian/atlasboard. Make sure you have Git and Node installed and then follow the instructions there to get the demo dashboard running. The link you posted is to a specific package for the dashboard. Basically you install the framework (my link) then you can pull in others' widgets as git submodules - like the one you linked.
I found this
https://bitbucket.org/atlassian/atlasboard-atlassian-package/overview
I have not been able to get any of it working.
Where do I copy this to? (Git pull)
When running "atlasboard start 3333" I don't see this Atlassian page. Where is it supposed to be?
Did you ever have any luck?
Learn more
