I have an error when i ran manual build for plan in bamboo version 3.3.3.
com.atlassian.bamboo.repository.RepositoryException : Build 'MY-PROJECT' failed to check SVN repository
When i do a checout wtith jsvn console client, then i have no errors.
./jsvn co http://(Repository URL from bamboo)/trunk/
bamboo-3.3.3
svnkit-1.7.6
subverion 1.7.2-1
Please help to resolve this issue
Here is a log mesage:
2012-12-21 13:07:10,302 INFO [qtp19930840-16] [SvnRepository] Checking externals at path 'externals/nedmalloc' with SVN URL 'http://svn:1080/repo/components/nedmalloc/tags/20121121/export' from revision 61353
2012-12-21 13:07:10,415 INFO [qtp19930840-16] [SvnRepository] Collecting changes for 'MY-PROJECT' on path 'http://svn:1080/repo/components/nedmalloc/tags/20121121/export' from version 61354 to 67688
2012-12-21 13:07:10,524 ERROR [qtp19930840-16] [ManualBuildDetectionAction] Error encountered while triggering manual build: Build 'MY-PROJECT' failed
com.atlassian.bamboo.repository.RepositoryException: Build 'MY-PROJECT' failed to check SVN repository
at com.atlassian.bamboo.repository.svn.SvnRepository.collectChangesSinceLastBuild(SvnRepository.java:313)
at com.atlassian.bamboo.v2.trigger.DefaultChangeDetectionManager.collectChangesSinceLastBuild(DefaultChangeDetectionManager.java:175)
at com.atlassian.bamboo.v2.trigger.DefaultChangeDetectionManager.collectChangesSinceRevisions(DefaultChangeDetectionManager.java:121)
at com.atlassian.bamboo.v2.trigger.DefaultChangeDetectionManager.collectChangesSinceRevisions(DefaultChangeDetectionManager.java:107)
at com.atlassian.bamboo.v2.trigger.DefaultChangeDetectionManager.collectAllChangesSinceLastBuild(DefaultChangeDetectionManager.java:99)
at com.atlassian.bamboo.v2.trigger.ManualBuildDetectionAction.process(ManualBuildDetectionAction.java:88)
at com.atlassian.bamboo.chains.ChainExecutionManagerImpl.createChainState(ChainExecutionManagerImpl.java:202)
at com.atlassian.bamboo.chains.ChainExecutionManagerImpl.start(ChainExecutionManagerImpl.java:125)
at sun.reflect.GeneratedMethodAccessor413.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:597)
at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:304)
at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:198)
at $Proxy64.start(Unknown Source)
at com.atlassian.bamboo.plan.PlanExecutionManagerImpl.startWithLockTaken(PlanExecutionManagerImpl.java:221)
at com.atlassian.bamboo.plan.PlanExecutionManagerImpl.access$100(PlanExecutionManagerImpl.java:39)
at com.atlassian.bamboo.plan.PlanExecutionManagerImpl$1.call(PlanExecutionManagerImpl.java:202)
at com.atlassian.bamboo.plan.PlanExecutionManagerImpl$1.call(PlanExecutionManagerImpl.java:196)
at com.atlassian.util.concurrent.ManagedLocks$ManagedLockImpl.withLock(ManagedLocks.java:324)
at com.atlassian.bamboo.plan.PlanExecutionLockServiceImpl.lock(PlanExecutionLockServiceImpl.java:68)
at com.atlassian.bamboo.plan.PlanExecutionManagerImpl.doWithProcessLock(PlanExecutionManagerImpl.java:337)
at com.atlassian.bamboo.plan.PlanExecutionManagerImpl.start(PlanExecutionManagerImpl.java:195)
at com.atlassian.bamboo.plan.PlanExecutionManagerImpl.startManualExecution(PlanExecutionManagerImpl.java:118)
at com.atlassian.bamboo.plan.PlanExecutionManagerImpl.startManualExecution(PlanExecutionManagerImpl.java:111)
at com.atlassian.bamboo.v2.ww2.build.TriggerManualBuild.doExecute(TriggerManualBuild.java:41)
at com.atlassian.bamboo.ww2.BambooActionSupport.execute(BambooActionSupport.java:969)
at sun.reflect.GeneratedMethodAccessor364.invoke(Unknown Source)
at com.opensymphony.xwork.DefaultActionInvocation.invokeAction(DefaultActionInvocation.java:358)
at com.opensymphony.xwork.DefaultActionInvocation.invokeActionOnly(DefaultActionInvocation.java:218)
at com.opensymphony.xwork.DefaultActionInvocation.invoke(DefaultActionInvocation.java:192)
at com.opensymphony.xwork.interceptor.DefaultWorkflowInterceptor.doIntercept(DefaultWorkflowInterceptor.java:175)
at com.atlassian.bamboo.ww2.interceptors.BambooWorkflowInterceptor.doIntercept(BambooWorkflowInterceptor.java:37)
at com.opensymphony.xwork.interceptor.MethodFilterInterceptor.intercept(MethodFilterInterceptor.java:86)
at com.opensymphony.xwork.DefaultActionInvocation.invoke(DefaultActionInvocation.java:190)
at com.opensymphony.xwork.validator.ValidationInterceptor.doIntercept(ValidationInterceptor.java:116)
at com.atlassian.bamboo.ww2.interceptors.BambooValidationInterceptor.doIntercept(BambooValidationInterceptor.java:33)
at com.atlassian.bamboo.ww2.interceptors.JSONValidationInterceptor.intercept(JSONValidationInterceptor.java:78)
at com.opensymphony.xwork.interceptor.AroundInterceptor.intercept(AroundInterceptor.java:31)
at com.opensymphony.webwork.interceptor.FileUploadInterceptor.intercept(FileUploadInterceptor.java:174)
at com.opensymphony.xwork.interceptor.I18nInterceptor.intercept(I18nInterceptor.java:151)
at com.atlassian.bamboo.security.acegi.intercept.web.WebworkSecurityInterceptor.intercept(WebworkSecurityInterceptor.java:54)
at com.atlassian.bamboo.security.acegi.intercept.web.WebworkSecurityInterceptorProxy.intercept(WebworkSecurityInterceptorProxy.java:30)
at com.atlassian.bamboo.ww2.interceptors.PaginationAwareInterceptor.intercept(PaginationAwareInterceptor.java:100)
at com.atlassian.bamboo.ww2.interceptors.StatisticsAwareInterceptor.intercept(StatisticsAwareInterceptor.java:42)
at com.atlassian.bamboo.ww2.interceptors.ResultsListAwareInterceptor.intercept(ResultsListAwareInterceptor.java:45)
at com.atlassian.bamboo.ww2.interceptors.NavigationAwareInterceptor.intercept(NavigationAwareInterceptor.java:97)
at com.atlassian.bamboo.ww2.interceptors.BuildResultsSummaryAwareInteceptor.intercept(BuildResultsSummaryAwareInteceptor.java:66)
at com.atlassian.bamboo.ww2.interceptors.ResultsSummaryAwareInteceptor.intercept(ResultsSummaryAwareInteceptor.java:74)
at com.atlassian.bamboo.ww2.interceptors.ChainAwareInterceptor.intercept(ChainAwareInterceptor.java:112)
at com.opensymphony.xwork.interceptor.ExceptionMappingInterceptor.intercept(ExceptionMappingInterceptor.java:186)
at com.opensymphony.xwork.DefaultActionProxy.execute(DefaultActionProxy.java:116)
at com.opensymphony.webwork.dispatcher.DispatcherUtils.serviceAction(DispatcherUtils.java:274)
at com.opensymphony.webwork.dispatcher.FilterDispatcher.doFilter(FilterDispatcher.java:202)
at com.atlassian.bamboo.ww2.BambooFilterDispatcher.doFilter(BambooFilterDispatcher.java:30)
at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1322)
at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:46)
at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter$1.doFilter(DelegatingPluginFilter.java:66)
at com.atlassian.applinks.core.rest.context.ContextFilter.doFilter(ContextFilter.java:25)
at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:74)
at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:42)
at com.atlassian.plugin.servlet.filter.ServletFilterModuleContainerFilter.doFilter(ServletFilterModuleContainerFilter.java:77)
at com.atlassian.plugin.servlet.filter.ServletFilterModuleContainerFilter.doFilter(ServletFilterModuleContainerFilter.java:63)
at com.opensymphony.module.sitemesh.filter.PageFilter.parsePage(PageFilter.java:118)
at com.opensymphony.module.sitemesh.filter.PageFilter.doFilter(PageFilter.java:52)
at com.opensymphony.webwork.dispatcher.ActionContextCleanUp.doFilter(ActionContextCleanUp.java:88)
at com.atlassian.bamboo.filter.AccessLogFilter.doFilter(AccessLogFilter.java:66)
at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:265)
at org.acegisecurity.providers.anonymous.AnonymousProcessingFilter.doFilter(AnonymousProcessingFilter.java:125)
at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:275)
at com.atlassian.bamboo.filter.SeraphLoginFilter.doFilter(SeraphLoginFilter.java:74)
at org.acegisecurity.util.FilterChainProxy.doFilter(FilterChainProxy.java:149)
at org.acegisecurity.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:98)
at com.atlassian.bamboo.filter.BambooAcegiProxyFilter.doFilter(BambooAcegiProxyFilter.java:25)
at com.atlassian.bamboo.filter.LicenseFilter.doFilter(LicenseFilter.java:73)
at com.atlassian.core.filters.AbstractHttpFilter.doFilter(AbstractHttpFilter.java:31)
at com.atlassian.johnson.filters.AbstractJohnsonFilter.doFilter(AbstractJohnsonFilter.java:71)
at com.atlassian.seraph.filter.SecurityFilter.doFilter(SecurityFilter.java:211)
at com.atlassian.seraph.filter.BaseLoginFilter.doFilter(BaseLoginFilter.java:150)
at com.atlassian.oauth.serviceprovider.internal.servlet.OAuthFilter.doFilter(OAuthFilter.java:71)
at com.atlassian.security.auth.trustedapps.filter.TrustedApplicationsFilter.doFilter(TrustedApplicationsFilter.java:98)
at org.springframework.orm.hibernate.support.OpenSessionInViewFilter.doFilterInternal(OpenSessionInViewFilter.java:170)
at com.atlassian.bamboo.persistence.BambooSessionInViewFilter.doFilterInternal(BambooSessionInViewFilter.java:31)
at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:75)
at com.atlassian.bamboo.filter.CompressingFilter.doFilter(CompressingFilter.java:75)
at com.atlassian.bamboo.filter.RequestCacheThreadLocalFilter.doFilter(RequestCacheThreadLocalFilter.java:31)
at org.springframework.web.filter.CharacterEncodingFilter.doFilterInternal(CharacterEncodingFilter.java:96)
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:473)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:119)
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:516)
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:226)
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:921)
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:403)
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:184)
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:856)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:117)
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:114)
at org.eclipse.jetty.server.Server.handle(Server.java:352)
at org.eclipse.jetty.server.HttpConnection.handleRequest(HttpConnection.java:596)
at org.eclipse.jetty.server.HttpConnection$RequestHandler.headerComplete(HttpConnection.java:1052)
at org.eclipse.jetty.http.HttpParser.parseNext(HttpParser.java:590)
at org.eclipse.jetty.http.HttpParser.parseAvailable(HttpParser.java:212)
at org.eclipse.jetty.server.HttpConnection.handle(HttpConnection.java:426)
at org.eclipse.jetty.io.nio.SelectChannelEndPoint.handle(SelectChannelEndPoint.java:510)
at org.eclipse.jetty.io.nio.SelectChannelEndPoint.access$000(SelectChannelEndPoint.java:34)
at org.eclipse.jetty.io.nio.SelectChannelEndPoint$1.run(SelectChannelEndPoint.java:40)
at org.eclipse.jetty.util.thread.QueuedThreadPool$2.run(QueuedThreadPool.java:450)
at java.lang.Thread.run(Thread.java:619)
Caused by: org.tmatesoft.svn.core.SVNException: svn: E160013: '/repo/!svn/bc/61354/components/nedmalloc/tags/20121121/export' path not found: 404 Not Found (http://esvn:1080)
at org.tmatesoft.svn.core.internal.wc.SVNErrorManager.error(SVNErrorManager.java:64)
at org.tmatesoft.svn.core.internal.wc.SVNErrorManager.error(SVNErrorManager.java:51)
at org.tmatesoft.svn.core.internal.io.dav.DAVRepository.getLocationsImpl(DAVRepository.java:1064)
at org.tmatesoft.svn.core.io.SVNRepository.getLocations(SVNRepository.java:1088)
at org.tmatesoft.svn.core.io.SVNRepository.getLocations(SVNRepository.java:1516)
at org.tmatesoft.svn.core.internal.wc2.SvnRepositoryAccess.getLocations(SvnRepositoryAccess.java:178)
at org.tmatesoft.svn.core.internal.wc2.ng.SvnNgRepositoryAccess.createRepositoryFor(SvnNgRepositoryAccess.java:45)
at org.tmatesoft.svn.core.internal.wc2.remote.SvnRemoteLog.run(SvnRemoteLog.java:160)
at org.tmatesoft.svn.core.internal.wc2.remote.SvnRemoteLog.run(SvnRemoteLog.java:35)
at org.tmatesoft.svn.core.internal.wc2.SvnOperationRunner.run(SvnOperationRunner.java:20)
at org.tmatesoft.svn.core.wc2.SvnOperationFactory.run(SvnOperationFactory.java:1235)
at org.tmatesoft.svn.core.wc2.SvnOperation.run(SvnOperation.java:291)
at org.tmatesoft.svn.core.wc.SVNLogClient.doLog(SVNLogClient.java:967)
at org.tmatesoft.svn.core.wc.SVNLogClient.doLog(SVNLogClient.java:872)
at com.atlassian.bamboo.repository.svn.SvnRepository.detectCommitsForUrl(SvnRepository.java:440)
at com.atlassian.bamboo.repository.svn.SvnRepository.collectChangesSinceLastBuild(SvnRepository.java:295)
... 176 more
Bruski,
I attempted to see the information at that link but was blocked. I even logged into my Atlassian account first and tried again, still no joy. All I get is "The connection has timed out The server at svn is taking too long to respond." Could you post the solution here please.
We are running Bamboo 3.4.4 so if a 4.3 is required, this could be our problem as well.
has anything on this path been deleted and recreated with the same name? If so, it's a bug that has been fixed in the latest 4.3 release.
I keep seeing 'Fixed in Bamboo 4.3.3. This may not be true according to Simone Longoni, he states "... Any luck with Atlassian Support? How did you get it solved?
I have the same issue with a couple of plans on Bamboo 4.4.3 and Subversion 1.6x...." (https://answers.atlassian.com/questions/141927/svn-checkout-fails-while-running-job-in-bamboo) .
You might want to go to that post and let Simone Longoni know how Atlassian got it solved...if it is solved.
