bitbucket commit hook
ajeet_singh
A use case to work on.
1. In this file, to the last row of <property> tag, the value part is a directory path,(app-7-25-0) should be same as changeSet id (last tag of file)
2.All property tag should be define before include file
3.All include tag after property tag
--- a certain xml file content ---
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
   <property name="BU_env_file" value="${envfile}" />
   <property name="release_home" value="${homedir}/GuiderLiqbs" />
   <property name="SIR-X12345A.home" value="${release_home}/schema_change/app-7-21-0/SIR-X12345A" />
   <property name="SIR-N22993A.home" value="${release_home}/schema_change/app-7-21-0/SIR-N22993A" />
   <property name="SIR-Y72345A.home" value="${release_home}/schema_change/app-7-25-0/SIR-Y72345A" />
        <include file="${SIR-X12345A.home}/01-backup.xml" />
        <include file="${SIR-N22993A.home}/01-backup.xml" />
        <include file="${SIR-X12345A.home}/02-schema.xml" />
        <include file="${SIR-N22993A.home}/02-schema.xml" />
        <include file="${SIR-X12345A.home}/03-schema-view.xml" />
        <include file="${SIR-N22993A.home}/03-schema-view.xml" />
        <include file="${SIR-Y72345A.home}/01-backup.xml" />
        <include file="${SIR-Y72345A.home}/02-schema.xml" />
    <changeSet author="MajorVersion" id="app-7-25-0" />
</databaseChangeLog>
Gonchik Tsymzhitov
Hi!
Sorry, about which file do you explain?
ajeet_singh
Hi Gonchik,
xyz.xml file
