bitbucket-pipelines.yml - git command not found
ffmit July 1, 2018 edited
Hello guys,
The problem is, when I push changes to Bitbucket and these are then pushed to Heroku the git command is not found.
  • Laravel PHP info app with phpinfo view, no extras
  • Bitbucket Cloud with Heroku pipeline
  • Heroku app accordingly configured
Please see my bitbucket-pipelines.yml in link to pastebin
When the pipeline step "Deploy to Heroku" runs, it aborts saying
git push
https://heroku:$HEROKU_API_KEY@git.heroku.com/$HEROKU_APP_NAME.git HEAD
bash: git: command not found
In the build setup, the installation of git successfully finishes. Screenshot
Why does the git command afterwards fail?
Thanks in advance!
Jeroen De Raedt
July 18, 2018
Hey @ffmit,
this is most likely because the git client is not installed in the Docker image that you are using (php:7.1.3).
You can either look for a different image that has git installed, or try installing it (e.g. through `apt-get install git-core` as the first command of your script).
ffmit July 31, 2018
Hello @Jeroen De Raedt,
thanks for your reply, but it is not working, my pipeline is this:
# This is a sample build configuration for PHP.
# Check our guides at https://confluence.atlassian.com/x/e8YWN for more examples.
# Only use spaces to indent your .yml configuration.
# You can specify a custom docker image from Docker Hub as your build environment.
image: php:7.1.3
pipelines:
default:
- step:
name: Set up the docker container
caches:
- composer
script:
- apt-get update && apt-get install -y unzip git git-core libc-client-dev libkrb5-dev && rm -r /var/lib/apt/lists/*
- docker-php-ext-configure imap --with-kerberos --with-imap-ssl && docker-php-ext-install -j$(nproc) imap
- curl -sS https://getcomposer.org/installer | php -- --install-dir=/usr/local/bin --filename=composer
- composer install
- vendor/bin/phpunit
- step:
# set HEROKU_API_KEY and HEROKU_APP_NAME environment variables
# set clone `depth: full' as described here: https://confluence.atlassian.com/x/Y9-5Mw
name: Deploy to Heroku
deployment: test # set to test, staging or production
# trigger: manual # uncomment to have a manual step
script:
- git push https://heroku:$HEROKU_API_KEY@git.heroku.com/$HEROKU_APP_NAME.git HEAD
It still fails with: "+ git push https://heroku:$HEROKU_API_KEY@git.heroku.com/docster-test.git master
Jeroen De Raedt
July 31, 2018
Hey @ffmit,
you installed git in your first step - whereas it is actually needed in your second step.
Try updating your second step to:
- step:
script:
Like • DuLobo likes this
ffmit August 4, 2018 edited
thanks a thousand times! Indeed, it was the problem that I thought that in the first step I do prepare the whole environment and that in the second step I use it.
Would be great if you could point me (and maybe others) into the right direction at the docs, where this is explained.
Have a nice day, thanks!
Kerstin_Schulze063
September 12, 2018
each step runs in an seperate docker container so you need to prepare it in the same step as you use it, on the other hand this makes it possible to run different steps with different docker images ^^ this was said in the summit 2016 video on youtube if i remember it rigth
Chris Habgood August 5, 2023
I am still getting git command is not found.
atlassian, confluence administration certification, atlassian certified professional, confluence admin for cloud, atlassian learning, confluence training, confluence certification exam, confluence cloud admin, admin credential, atlassian certification
Become a certified Confluence admin today! 📖
Stand out as a skilled Confluence Cloud administrator. The Confluence Administration for Cloud certification proves you can configure permissions, manage site and space settings, and monitor activity—ensuring secure, effective collaboration for your team.
