error: RPC failed; curl 56 HTTP/2 stream 5 was reset
Andrejs Tolstojs
June 14, 2023
I can do all actions with all branches except one. I need to push. I use https
Patrik S
June 15, 2023
Hello @Andrejs Tolstojs and welcome to Atlassian Community!
The error being returned indicates an issue related to the network. In this case, would it be possible for you to try executing the push from a different network and confirm if the error persists? You can try testing using your cellular data, for example.
Also, as you mentioned being using HTTPS protocol, could you try switching to SSH and check if the error also occurs ? You can follow the instructions on Setup personal SSH keys
Thank you, @Andrejs Tolstojs !
Patrik S
Andrejs Tolstojs
June 15, 2023
Thanks, Patrik
I solved the problem by switching to HTTP1.1
Like Patrik S likes this
