×i have external hook plugin installed. After enable it for both pre and post receive hooks, it only works for pre-receive hook, but not triggered for post-receive hook. I had made sure the executable files runs properly in the path. but the hook apparently is not being called. What did i missed here? Thanks.
Stanislav,
I downloaded & build 1.3-10 version of hook. The post-receive hook plugin still not working
Can you post what exactly you specifying as post-receive hook? I've just checked out and it works in my installation. Also, you can try to specify following test data: Executable: /bin/sh Params: -c echo test > /tmp/testing-hook
Stanislav, My apology for not correct comments: the post-receive hook triggered but I never get messages from it. Example: in post-receive hook executable is: C:\tmp\run-post.bat Content of this file: echo HELLO POSTRECEIVE HOOK C:\tmp\rep_1>git push origin new-branch Password for 'http://admin@testserver:7990';: Counting objects: 7, done. Delta compression using up to 2 threads. Compressing objects: 100% (2/2), done. Writing objects: 100% (3/3), 268 bytes | 0 bytes/s, done. Total 3 (delta 1), reused 0 (delta 0) remote: remote: Create pull request for new-branch: remote: http://testserver:7990/stash/projects/PROJECT_1/repos/rep_1/compare/commits?sourceBranch=refs/heads/new-branch remote: To http://admin@testserver:7990/stash/scm/project_1/rep_1.git * [new branch] new-branch -> new-branch As you see, there is no output here. If I set same file in pre-receive hook, all output messages were printed out here. The atlassian stash log file does not show any output messages from script. If I follow your wiki page: (https://github.com/ngsru/atlassian-external-hooks/wiki/Documentation), the log file (test-params.log) was created with correct content. Can we print out some messages to client?
Ok, sorry, I've got it. Current implementation doesn't support sync post-receive hooks (looks like it was addeed into Stash recently), so currently there is no way to show something from post-receive. However, looks like it's not big deal to implement it, so look forward to 1.4 version which will support sync and async hooks.
Uh-oh. I was wrong, there is still no support for repo-specific sync post-receive hooks in Stash. So, there is no way to see something as output of post-receive hook. If output is cruicial it's better to use pre-receive hooks (anyway, everything available in post-receive hook is also available in pre-receive hook).
Vivian, I've just uploaded new version (1.2-1) of plugin with Charles PR merged in. Can you try it with your configuration and see what will be popped out in logs?
I removed my previous comments. The external post receive hook plugin still not working. It's not being triggered at all. The atlassian_stash.log did not show this plugin is being called. I'll have to switch back to put the hook in post-receive.d directory instead.
Hi Vivian,
Apologies, I'm assuming you mean this plugin?
https://marketplace.atlassian.com/plugins/com.ngs.stash.externalhooks.external-hooks
I've created a pull-request to fix the logging in the plugin:
thank you for your reply. It worked after putting it into pre-receive.d. This should solve our problem. However, my original question was regarding the external hook plugin that we installed. It works for pre-receive external hook but not for post receive.
Hi Vivian,
Where did you put the file exactly? Did you add them to the pre-receive.d and post-receive.d directories? I'm assuming when you pushed the commit succeeded? If you use a post-receive plugin in Stash does it work (on a test URL for example)?
If you get stuck don't hesitate to raise a support ticket as well (with a support ticket attached) so we can take a closer look.
Charles
