fatal: No such remote 'origin' (after git remote set-url origin https://...)
robert kofler
My code is already tracked by Git
If your code is already tracked by Git then add this repository as a new repository that you can push to.
I cd to /path/to/my/already_tracked/.git
git remote set-url origin https://user:server:port/scm/ABC/my_stash_repo.git
leads to:
also a "git remote -v " does not show the above stash-repo.
what is wrong in my thinking?
70 votes
Stefan Saasen
December 15, 2012
The above will only work if you've either cloned the repository or manually added a remote called origin.
If "git remote -v" doesn't show you any remotes you can simply add a remote using:
git remote add origin https://username@stash/scm/PROJECT/repo.git
The name of the remote doesn't have to be "origin" and can be any name that makes it easier for you to identify that particular remote (e.g. "stash").
HTH,
Stefan
Destin Coleman
July 15, 2019
Dude, 7 years later and you are still saving lives
Like # people like this
Daniel Russell
September 18, 2019
Yeah. I don't get it. I'm pretty new to git and thoroughly frustrated and confused at this stage. But at any rate, I think this should work and doesnt. Here's my git remote -v:
origin https://github.com/danielmrussell/Vulkan-Loader.git (fetch)
origin https://github.com/danielmrussell/Vulkan-Loader.git (push)
upstream https://github.com/KhronosGroup/Vulkan-Loader.git (fetch)
upstream https://github.com/KhronosGroup/Vulkan-Loader.git (push)
And weirdly, I somehow managed to submit a Pull Request from the extension finally, despite the fact that I am still getting flooded with these error messages:
[Info] Looking for git repository
[Info] Git repository found, initializing review manager and pr tree view.
[Info] Review> Validate state in progress
[Info] Review> Validating state...
[Info] No remote with name 'origin' found. Please update your 'githubPullRequests.remotes' setting.
[Info] No remote with name 'upstream' found. Please update your 'githubPullRequests.remotes' setting.
[Info] No GitHub remotes found
[Info] Review> Queuing additional validate state
[Info] Found GitHub remote
[Info] https://api.github.com: GraphQL support detected
[Info] Review> current branch master is associated with pull request #250
[Info] Review> Resolving pull request
[Info] Review> Fetching pull request data
[Info] Review> register comments provider
[Info] Review> display pull request status bar indicator and refresh pull request tree view.
What gives?
Alex McDowell
August 2, 2020
8 years later and you're still saving lives. Thank you so much!!!!!
Like Shawn Veltman likes this
15 votes
Nate Pendleton
June 24, 2014
It would be nice if the Stash instructions on the new empty repo page mentioned this.
Michael Kotthaus
April 7, 2017
Yes, I also noticed that the remote must be added, before you can specify an URL with set-url.
