i am new to crucible and fisheye
when i add a git repository in fisheye 2.3.6 ,start error comes,
Errors:
Exception executing command "git ls-remote -h git@192.168.10.4:R722XA10982301 " java.io.IOException: Cannot run program "git": CreateProcess error=2, The system cannot find the file specified
com.atlassian.fisheye.plugins.scm.utils.process.ProcessException - java.io.IOException: Cannot run program "git": CreateProcess error=2, The system cannot find the file specified
java.io.IOException - Cannot run program "git": CreateProcess error=2, The system cannot find the file specified
java.io.IOException - CreateProcess error=2, The system cannot find the file specified
Error talking to repository:
Error testing connection.
com.cenqua.fisheye.config.ConfigException - Problem talking to repository
Connection failed.
do i have to config other settings ?
my jira version is 4.4.1 ,git version is 1.7.0.4
Hi I am also facing same problem?
Hi fabby,
Maybe you need to verify the Git PATH defined for FishEye. Please review your configurations using documentation below:
https://confluence.atlassian.com/display/FISHEYE/Git
I hope it helps you.
Leonardo.
